Is it time to upgrade my fuel injectors?
Old Mar 23, 2012 | 11:06 PM
midnighttheg35's Avatar
My car has 187000 km on it and the last owner did hardly any maintainence. Im doing as much as i can but do you think i need to replace the fuel injectors? If so, should i
Upgrade or is it just a waste to upgrade? Any help is appreciated. Thanks!
Idk if it makes a difference but its an 06 6mt running 94 octane.
Old Mar 24, 2012 | 09:45 AM
gary c's Avatar
If you have a concern about your injectors find an independent Nissan mechanic and have them put thru the cleaning process. They just run cleaner thru the injectors while the car is running. How bout the rest of the maintenance, trans/diff/radiator?
Gary
Old Mar 24, 2012 | 12:05 PM
walshtj's Avatar
Gary
+1 I just had mine done at Nissan of Charlotte.
Old Mar 24, 2012 | 03:18 PM
TemjinX2's Avatar
i would just go to one of those cheap dyno days and get a afr ratio read out with your dyno. if the afr lines look kind of weird, then i would look more into about getting them replaced. But all name brand gasoline (chevron, shell, 76) comes with additives that keeps fuel injectors clean.
jsimonk
Dec 22, 2023 03:49 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
newg37
Jul 26, 2015 09:32 AM
