I hate the air cleaner system
Old Apr 11, 2012 | 09:53 PM
rsingerG35's Avatar
Hi,
Didn't realize how much of a pain it is to change the air filter. THEN when I went to cut off the zip tie to move the MAF wire whole piece of plastic broke off that the zip tie goes through. And me and my OCD it's bothering me. To bad that air cleaner cover is like 85 dollars.
Old Apr 11, 2012 | 10:49 PM
MADtotheA's Avatar
What?! That's like the easiest thing to do on our cars!
Old Apr 11, 2012 | 10:50 PM
rsingerG35's Avatar
I am used to just having 4 clips. Not removing the entire system.
Old Apr 11, 2012 | 11:24 PM
blaccG35's Avatar
just super glue it back
Old Apr 12, 2012 | 11:54 AM
Tabris's Avatar
If you enjoyed that one, the in cabin air filter is worse
Though both easy anyway..
Old Apr 12, 2012 | 04:21 PM
That's G's Avatar
I just did this as well and I honestly don't think I even zip tied the wires back. Didn't seem to be a point.
Old Apr 12, 2012 | 10:35 PM
jonesmeister11's Avatar
I think the intake is easy...
Old Apr 12, 2012 | 11:19 PM
MADtotheA's Avatar
Originally Posted by kidtronix
I'd much rather change the cabin filter over the engine air filter any day. What a PITA that intake is.
Thanks for the reminder. Gotta change mine this weekend since all the pollen is gone. What a mess my allergies have been!
Old Apr 12, 2012 | 11:35 PM
Tabris's Avatar
Yeah. I clipped the zip tie to remove the wire, and simply stuck the wire back into the cut clip afterwords. It didn't look like it would matter though.
Opposite for me. The engine filter had a few steps and was easy to access. The cabin filter had more steps and was a pain to get at. (Apparently.. the wire that I was struggling with/tugging on, was for the airbag... )
Old Apr 13, 2012 | 09:13 AM
gary c's Avatar
Originally Posted by rsingerG35
Hi,
If you have issues with the intake filter........you must love checking your oil....Gary
Old Apr 13, 2012 | 09:27 AM
LoSt180's Avatar
Why cut the zip tie for the MAF wire? You could've squeezed the ends of that clip with some needle nose pliers and pushed it though... Since you're all OCD.
Old Apr 13, 2012 | 11:05 AM
Jhambor's Avatar
Wow, if you had a hard time with that....might be a good idea to just have a professional work on your car from now on! Surpised you don't throw a fit when you have to pop your gas door and unscrew the cap to fill up your tank.
Old Apr 13, 2012 | 11:11 AM
That's G's Avatar
Man, you had to have known you were going to get burned to the ground for this thread OP
Old Apr 13, 2012 | 03:37 PM
DGP-G35's Avatar
Give the guy a break, I have 20+ years in automotive and honestly the airbox was a little irritating the first time I dealt with it (sure it's easy after you have done it once but my guess is this is his first time changing the filter).
Jason
Old Apr 13, 2012 | 03:41 PM
prinny's Avatar
Oh god -___-.. it's like next to impossible to check the damn oil. Can't ever tell.
