Tires That Came On Car Aren't OEM Size?
Old May 8, 2012 | 09:24 PM
JHands's Avatar
New 6mt owner here. The recommended size for my 06 6mt sports package is 220 40 19 front and 245 40 19 for the rear. I was checking pressures today and noticed the previous owner had a set of 4 falken fk452s mounted. The fronts are 245 35 19 and rears are 255 40 19. Any reason for this? I am going to be needing rears soon. Now that I noticed the size discrepancy I am debating doing the fronts too then retaining them and selling on Craigslist because they still have tread. Are these tires filling up the wheel wells more than the stock sizes? Any recommendations for a good tire with decent performance properties, long lasting, cheap price? I know there will be some trade offs in each category. Should I stay with the sizes on there or go OEM? What differences would I notice? Thanks for your replies in advance.
Old May 8, 2012 | 10:53 PM
gary c's Avatar
I never liked that Nissan put 225s on the front and 245s out back, our coupes are more stable with 245s on the front especially at freeway speeds. You could run 245/35X19 on all four corners for a great ride. The words "Good Tire & Cheap Price" don't belong in the same paragraph. Check www.thetirerack.com for a good tire with a UTQG of 300 that will get you 30K+ miles of service and still work on your G35 with good traction. UTQG is the wear rating, below 300 and tire life will be shortened over and you'll have traction/stopping issues....Gary
Old May 8, 2012 | 10:56 PM
JHands's Avatar
So should I keep the set up that's on there now?
Old May 8, 2012 | 11:29 PM
GT3050's Avatar
I use the same 245/35/19 front and 255/40/19 setup and like it better than the oem 225/40/19 245/40/19
Old May 9, 2012 | 12:06 AM
herrschaft's Avatar
The previous owner probably didn't like understeer, or the sight of a narrow tire. Having 245's in the front will help improve handling a little. The only benefit of going back to a 225 on the front is slightly cheaper tires. It sounds to me like you don't care about the handling that much anyways so you need to prioritize what you want out of a particular tire. Yes there are tradeoffs since there is no "perfect" tire.
Old May 9, 2012 | 08:56 AM
gary c's Avatar
Sure, buy the 245s for the front and get all the wear you can out of those back tires....Gary
Old May 9, 2012 | 10:05 AM
herrschaft's Avatar
Another benefit of having a square setup is being able to put the rear wheels on the front to equalize tire wear.
Old May 9, 2012 | 02:04 PM
JHands's Avatar
The rear rims are wider on my vehicle I thought? So that wouldn't work.
Old May 9, 2012 | 06:11 PM
Keggr626's Avatar
Assuming ur wheels are the 19" Rays yes the rears are a half inch wider. U won't be able to rotate them
Old May 9, 2012 | 06:16 PM
JHands's Avatar
Anyone have any experience with nexen n3000 tires on our cars? Price is cheap and reviews for other cars are good but curious about on the G.
Old May 9, 2012 | 08:29 PM
herrschaft's Avatar
They're 0.5" wider and a few lbs heavier, not like we're talking about a massive stagger here. If you have the same size tires all around then the rear wheels CAN be put on the front without any problems. Other members and myself have done this on many occasions. I brought it up since the OP mentioned uneven wear between the front and rear tires, and this is a way to prevent that.
Old May 9, 2012 | 08:47 PM
JHands's Avatar
Well if the sidewall on the inside of the right front wasn't separating due to falkens **** design I would just replace the rears to cope with the uneven wear. Looks like I'm getting a full set.
Old May 10, 2012 | 07:28 AM
NYT's Avatar
NYT
You get what you pay for. These don't belong on a G.
Old May 10, 2012 | 08:18 AM
JHands's Avatar
Debating going with the Hankook v12. Anyone have any opinions on them? Also not sure whether to stick with the previous owners size preference or go back to factory size...what differences would I notice? What size fronts and rears are y'all using on your staggered rays?
Old May 26, 2012 | 12:08 PM
JHands's Avatar
Can anyone else with experience expand on this? I am strongly considering buying a square set up and rotating backs to fronts after some mileage, but am a little worried about putting the wider rims in the front. Does it throw anything off? Look funky?
