Axle click while braking instead of taking off?
Old May 12, 2012 | 01:50 PM
youloze's Avatar
UPDATE POST #21
Has anyone ever had the infamous axle click while braking instead of taking off from a stop?
Im getting a really bad grinding/clicking type sound from the passenger rear brakes while braking only. It only happens below about 20 mph and only at about 50%-60% braking force. Any more or any less force and it doesn't happen. Also, it seems to make the sound twice per rotation of the wheel at the same exact intervals every time.
Not sure if it's the axle click or not, actually Im pretty sure it's not but Im running out of ideas.
Here is a list of what I've checked and what it is NOT:
-NOT a seized brake caliper
-NOT the shims
-NOT the strut top mount nut
-Pretty sure it's not the pads or rotor as there aren't any groves in the rotor and they both seem to be wearing perfectly fine.
-All suspension nuts/bolts are tight
-Pretty sure it's not the wheel bearing either since the only time it makes noise is when braking and I've never heard a wheel bearing sound like this. Also, I tried to wiggle the wheel when it was jacked up and it doesn't budge.
Im out of ideas other than the axle. Any input or ideas would be appreciated.
Thanks!
Old May 12, 2012 | 03:07 PM
blues3531's Avatar
I have this going during light acceleration in first and second gear. As soon as I begin to accelerate from a stop I hear a single click.
Old May 12, 2012 | 06:41 PM
youloze's Avatar
Thanks for the reply but mine is ONLY while braking.
Old May 13, 2012 | 12:49 AM
manvelmk's Avatar
Do you by any chance drive my car? Same symptoms, haven't checked the cause though, been busy lately. Would like to know what it is. I hope it's not my axle
Old May 13, 2012 | 10:45 AM
DailyDrivenCoupe's Avatar
ive been having a weird brake issue like this as well, checked all the same things you have. mine is more of a croaking/clicking sound and only under the same braking conditions as you. if i wait and brake hard then no noise. subscribed to this
Old May 13, 2012 | 11:01 AM
youloze's Avatar
LOL wow I guess Im not the only one with this problem. Dont know if thats a good thing or a bad thing. Hopefully someone else that had this problem and resolved it will chime in.
In the meantime I think I'll go ahead and pull the axle, clean it and grease it up since its an easy enough job. I'll report back with results.
Old May 13, 2012 | 11:21 AM
sounds good let us know how that works out for you!
Old May 13, 2012 | 12:18 PM
vegaszx10's Avatar
Are you talking about the shin on the pad. Check the hardware on the caliper bridge make sure the when the pads are sitting on it there's no play.
Old May 13, 2012 | 12:30 PM
youloze's Avatar
Good question, all shims are greased and in good shape. When I say shims I mean the ones on the back of the pads themselves AND the ones that the pads mount in as well. I actually had a noise from the shims that the pads sit in when I bought the car but I greased them up and they are good now.
Good question though!
Old May 13, 2012 | 04:48 PM
vegaszx10's Avatar
Make sure the pads are tight on that shim cause if there's a little play you will hear a click.
Old May 13, 2012 | 06:09 PM
can you explain more about this noise...
Old May 13, 2012 | 09:19 PM
youloze's Avatar
It was a metal on metal creaking noise. What it was was the dry metal shim (that the pads mount in) rubbing on the metal caliper when the caliper flexes while braking.
If this is your noise, you'll know it by wiggling the shims on the caliper. I fixed it by greasing the shims, but now I have this new noise :-(
Old May 13, 2012 | 09:24 PM
ok well i highly doubt this is my problem. i have no metal on metal type screeching. but just to get some more information in this tread are you refering to the shims on the back of the brake pad or the actual hardware that the pad slides into that you greased
Old May 13, 2012 | 09:30 PM
youloze's Avatar
I greased both the back of the pads and the metal shims that they slide into. The piece that was making the creaking sound was the shim that they slide into, not the shims on the back of the pads themselves.
And just to clarify it was a creaking/clicking sound, not a screeching sound. Actually pretty close to this new sound Im getting.
BTW, I may be onto something with this new sound. I tried something out today and the noise went away but I need to test it a little more tomorrow before I can be sure of the results. I will post about it as soon as I have some more solid info.
Old May 13, 2012 | 10:06 PM
ok gotcha so you are refering to the actual hardware. when i hear shim i think the piece on the back on the brake pad itself. thanks for explaining. interested if u figured it out so keep us posted
