Do engines lose power over time?
Old Jun 11, 2012 | 12:47 AM
Plam's Avatar
Just wondering.. do engines lose horses over time? Like my 05 IP coupe g35... how many horses has it lost? lol 82k miles with K&N intake.
Off topic: In a straight line drag race, hypothetically speaking.. A lancer evo would beat a g35 due to AWD factor and power to weight ratio?
EDIT: I got my answer on the evo. But still want one for the main topic
Old Jun 11, 2012 | 01:22 AM
G35 Dream's Avatar
Yes they do loose power over time.
Old Jun 11, 2012 | 02:37 PM
Mr. Brett's Avatar
Yes, engines will lose power over time as they accumulate sludge, carbon buildup, and general wear and tear on the moving parts.
However, a properly maintained motor will see a lot less power loss as the miles rack up. If you keep fluids topped off and changed at regular intervals, and keep the motor tuned up, a car will last pretty much as long as you want it to.
My 5AT G coupe with 230k on the clock has been cared for by both myself and the PO. I can still give a Mustang GT a run for its money in the 1/4 mile.
Old Jun 11, 2012 | 06:08 PM
imsoulany's Avatar
wooo! props to maintaining your G at 230k on the clock!!
Old Jun 11, 2012 | 06:12 PM
VMRWheels's Avatar
+1
An engine that has been maintained and cared for will last a very very long time.
Old Jun 11, 2012 | 11:52 PM
Plam's Avatar
Is there anyway I can bring my car back to its original power? lol
Old Jun 12, 2012 | 01:00 AM
midnighttheg35's Avatar
Engine rebuild? Lol. Pricey but itll clean everything out and while your in there you could build everything up
Old Jun 12, 2012 | 01:48 AM
datbeans's Avatar
Engines gain power over time because the build up of carbon on the pistons will increase the compression ratio resulting in higher horsepower.
Not srs
partyman66's Avatar
LOL... There are no quick-fix ways to restore power to a tired motor. The way to restore power is to rebuild the motor and either sleeve the block or do a slight overbore with new pistons and rings and make sure everything with the valve-train is in spec with no compression leaks.
Old Jun 12, 2012 | 02:11 AM
obsidian_g35's Avatar
Rebuild would be the way, just a little pricey.
Old Jun 12, 2012 | 11:09 AM
Mr. Brett's Avatar
Rebuild or swap in a motor with lower miles.
You can get a few ponies back by putting in new spark plugs, SeaFoaming the motor, etc. But it's not going to be anything to write home about.
Old Jun 13, 2012 | 01:23 PM
devin7632's Avatar
yes they lose power
Old Jun 13, 2012 | 09:58 PM
jomamahama's Avatar
i do not think the power loss is significant on modern engines but i have no evidence to back that up.
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
