Headlight strip/side marker only works on passenger side
Old Jun 12, 2012 | 03:24 AM
LakeG35's Avatar
Hi all, anyone encounter this problem before? If so, please help!!!
The driver side of the headlight strip and side marker doesn't turn on. But passenger side working properly. Does that means bad fuse? I tried to change the bulb but still having same issue... Also, I tried to check the fuse behind the battery but didn't know which one to check.
Old Jun 12, 2012 | 08:02 PM
06G35Coupe94's Avatar
If you did change the bulbs and it still didnt work then check your fuses. Just search which ones it is on here or find it in your car manual...
Old Jun 13, 2012 | 12:25 PM
cvipgo's Avatar
Fuse no. 58
Old Jun 13, 2012 | 04:55 PM
LakeG35's Avatar
Originally Posted by cvipgo
Fuse no. 58
I spend hours searching at google plus looking at my 05 repair/service manual and couldn't find #58. Sorry, I am a newbie to this.
http://ww2.justanswer.com/uploads/fi...check_fuse.jpg
Old Jun 13, 2012 | 05:14 PM
cvipgo's Avatar
IN ESM and go look in PG section "POWER SUPPLY, GROUND & CIRCUIT ELEMENTS" you will have all the info - where every fuse is located and what connections it controls. GOOGLING is not going to help.
Go to page "IPDM E/R (INTELLIGENT POWER DISTRIBUTION MODULE ENGINE ROOM)"Schematic and follow & check all the fuses from the headlight LH back to battery.
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
wylin
Lights
Jul 18, 2015 06:12 PM
