stillen g35 vacuum leak?
Old Jun 12, 2012 | 03:03 PM
herzog racing's Avatar
I just picked up an auto 05 G35 last week with a stillen stage 2 kit and was wondering what the vacuum suppose to be at idle? its at -10.Also the car is a bit slow for my taste what would I need to do to make a little more power? what do I need for stage 3 pulley and where can I buy it?
Old Jun 12, 2012 | 03:26 PM
Silencer_0's Avatar
It should be at -20 at idle. Check for any obvious leaks or get a smoke test done. The Stillen kit simply doesn't make that much power, either swap it out with a Vortech kit or ST/TT setup. Most people go straight to Stage 4 with the Stillen.
Old Jun 12, 2012 | 03:40 PM
so the car being automatic has nothing to do with the vacuum siting at -10? also where can I find the stuff to go stage 3 or 4?
Old Jun 12, 2012 | 08:49 PM
_LiL_G_'s Avatar
They have vendors here that have stillten that can get you up to stage 4 just check the engine thread and make sure you research everything first
Old Jun 12, 2012 | 09:10 PM
Silencer_0's Avatar
^+1. And being 5AT has nothing to do with it. I have a 5AT with a Vortech and I idle at -20 vacuum.
Old Jun 13, 2012 | 03:46 AM
alright and will this boost leak affect my AFR? It drops below 11 with just a little rev
Old Jun 13, 2012 | 11:45 AM
Silencer_0's Avatar
Yes it does affect it, you need to get that fixed ASAP. What RPM do you idle at?
Old Jun 13, 2012 | 03:58 PM
let me check. and thanks for the help
Old Jun 13, 2012 | 07:12 PM
its sitting at 500rpm. and no leak now. it was a bad boost gauge. but the afr when I rev it a few times reads lean???? is that normal
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
newg37
Jul 26, 2015 09:32 AM
laksjd84
Jul 24, 2015 05:12 PM
