New spark plugs after OC engine replacement?
Old Jun 21, 2012 | 04:33 PM
Phontain's Avatar
My engine was burning a lot of oil when the dealer replaced it. I'm assuming the dealer did not replace the plugs during the engine replacement. Could this have damaged or prematurely worn out the plugs?
I'm replacing my engine belts so I thought I'd do it all at once.
Old Jun 21, 2012 | 05:56 PM
Imperial1's Avatar
if you know which cylinders were burning oil, i'd change those plugs as they'd be useless. (unless of course you haven't changed the plugs in awhile then I'd just change all 6).
when my engine burned oil it was only the #4 cylinder.. took out that plug and it was toasted. All the other plugs were fine though as I had recently changed all the plugs. So when I got my engine swapped I only changed the spark plug in cylinder #4.
Old Jun 21, 2012 | 06:10 PM
Phontain's Avatar
Plugs have 44k miles on them. Ill replace them all.
Thanks
Old Jun 21, 2012 | 06:21 PM
irishsig's Avatar
Hmmm, I just had my short block replaced by the dealership.
I gotta check the invoice to see if they changed the plugs.
Old Jun 22, 2012 | 08:31 AM
Highestrich4's Avatar
i got an 07 sedan s and curious to know that since i have exhaust and intakes is there any certain plugs anyone recommends? Should i use a better brand or just swap them out for the stock generic kind?
Old Jun 22, 2012 | 01:04 PM
Blue Dream's Avatar
I drove ttrank's car solo
NGK Iridium is what a lot of us use.
Terry_G35
May 9, 2020 01:39 AM
wuppiedog
Aug 7, 2015 11:16 AM
ghost_g35
Aug 7, 2015 10:31 AM
Terry_G35
Aug 4, 2015 02:38 PM
Jadenkid22
Jul 14, 2015 12:33 AM
