05 Sport transmission issues?
Old Jun 26, 2012 | 08:48 PM
Koneko349's Avatar
New to the forum....
I have a stock 05 coupe with 90k miles on it. Recently I have noticed that sometimes when I am driving if I let of the accelerator and then go back to accelerate the car will jerk twice slightly. This doesn't happen all the time and the car seems to accelerate and shift between gears smoothly. This same jerking sensation happens on occason when letting off the accelerator at low speeds. Does anyone else have this issue? Should i be concerned?
Old Jun 27, 2012 | 09:57 PM
AuAltima3.5's Avatar
Two things come to mind: change the fluid and see what happens, or live with it.
There is a chance changing the fluid could make it worse, but at this point an issue exists that is going to require some kind of repair. In any event, the trans will either require removal or fluid to be drained, so start cheap and drain the fluid/refill 2 or 3 times.
You can also get the car checked for codes, you don't have to have a CEL to throw a code.
Old Jun 28, 2012 | 01:54 AM
Koneko349's Avatar
I had the trans flushed about 8k miles ago by the dealer. No shavings or anything they could find wrong. As for codes, i checked about a week ago, no codes. I can live with it since it is subtle i just didnt know of something was wrong/eeded to be fixed or of this was a normal thing others have felt... If replacing the whole thing is the only real solutoon, ill deal with it XD
tiguy99
Mar 1, 2016 11:42 AM
R350k5
Oct 1, 2015 08:41 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
newg37
Jul 26, 2015 09:32 AM
