Bad front hub assemblies, or something else?
Old Jun 26, 2012 | 10:44 PM
Jestered's Avatar
I noticed recently that when I'm pulling into a parking spot, when I turn the wheels, I hear a grinding noise. It almost sounds like a wobbling grinding sound. It makes that sound when turning either direction so I was going to order a pair of front hub assemblies, but thought I'd ask if this could be something else before I drop $300+ on parts that may not fix the problem.
Is this an obvious hub/bearing issue, or am I overlooking something else?
Old Jun 29, 2012 | 03:57 PM
Jestered's Avatar
I'm just gonna bump this once and then take the car in to have looked at if no one chimes in. Does anybody believe the hub/bearing assemblies in the front are bad? Is it possible that something else is causing this problem?
Old Jun 29, 2012 | 06:59 PM
fatlip's Avatar
Jack up the car and spin the wheels. If u can hear or feel grinding when u touch the upper A arm the bearing is bad. The 12 and 6 shake down didnt work for me but the wheel spin check did.
Cajuncowboy
Jun 21, 2021 09:47 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
teamghost
Jul 28, 2015 04:52 PM
will091195
Jul 27, 2015 09:19 PM
papo020
Jul 17, 2015 10:30 PM
