2007 coupe a/c & heater fan not working intermittently
Old Jul 2, 2012 | 10:32 PM
se_nismo's Avatar
Hey guys
I have a 2007 coupe and recently only when starting the car intermittently the fan control does not work. After a few minutes of playing with the fan control will start to work. Anyone encounter this issue or can point me into the correct area to start testing.
Any help will be appreciated
Greg
Old Jul 3, 2012 | 11:53 AM
rimshaker's Avatar
You mean both -/+ fan buttons won't respond? Could be worn out button contacts.
Old Jul 3, 2012 | 11:59 AM
gary c's Avatar
Take it by your local Nissan dealership, like the member....^....posted it's probably a worn switch/button and needs to be replaced.
Gary
Old Jul 3, 2012 | 01:36 PM
se_nismo's Avatar
Yeah both -/+ buttons don't respond. If the fan was working before I shut off the car, let's say it's in full blast fan setting I shut the car off and restart theres a good chance the fans will not turn even though the display indicates fan setting is at full
Old Aug 19, 2014 | 06:56 AM
were3r's Avatar
For intermittent fan problems, I fixed it by replacing the relay located in the fuse box. Fuse box is located next to the parking brake, to the left. There are other threads that show how to replace it.
On my 2007 G35 the relay is located behind the fuses at the bottom. There are 4 relays there.
check this:
https://g35driver.com/forums/general...mittent-2.html
Old Aug 19, 2014 | 12:22 PM
OBG3506's Avatar
^^ yeah just replace that relay, mine was doing the same thing, replaced the relay no more problems
Old Aug 19, 2014 | 12:31 PM
ACE420's Avatar
It's exactly the problem I had until I replaced my fan relays as mentioned above^^^ it's a cheap easy fix! Pls try this before you do anything expensive trust me I went thru a lot with this lol. And your problem is that you start car and it take a few minutes to kick on. Don't wait get it fixed ASAP as mine kept getting worse and worse until I changed it
champppy
Mar 31, 2020 12:25 PM
yassy
Aug 3, 2015 12:24 AM
Rehman2009
Jul 27, 2015 03:23 AM
justgotg35
Jul 19, 2015 12:33 PM
