Quick Question on Air Filters
Old Jul 6, 2012 | 12:25 PM
lostangels01's Avatar
I'm currently running the oem rev-up intake box, z-tube and K&N filter. I'm looking to change back to dry filters. I've read a few of you have the Amsoil air filter. Recommendations? Anyone else try out the Nismo S-Tune or Apexi Air Filter?
AMSOIL Ea Air Filter
http://www.amsoil.com/catalog.aspx?code=EAA74-EA
Nismo S-Tune Sports Air Filter
http://www.nengun.com/nismo/s-tune-sports-air-filter
Apexi Power Intake Panel Filter
http://www.conceptzperformance.com/C...92.231.133.253
Old Jul 6, 2012 | 12:30 PM
Jeff92se's Avatar
Red Card Crew
IMHO, it's best to run just a dry replacement filter and change it frequenty. IMHO, those dry types that you clean off again, never get all that clean again and eventually clog.
I happen to have a oem purolator filter for sale if you want to go that route.
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/engine-...oem-panel.html
Old Jul 6, 2012 | 01:10 PM
partyman66's Avatar
I'm very happy with my Amsoil EA Nanofiber filters. I have them in both my car and truck.
Old Jul 6, 2012 | 01:52 PM
That's G's Avatar
I'm running an Apex'i in a rev-up airbox. Honestly, an air filter is an air filter is an air filter IMO.
Old Jul 6, 2012 | 01:58 PM
partyman66's Avatar
Not true! I used to have a K&N in mine, and that thing let a $hit ton of dirt by. I had a film of small dirt particles on the inside of the clean side of my intake tube when I took that thing off and my oil used to get dirty much quicker prior to switching over to the Amsoil filter. I drive my car in really clean conditions too... I can't even imagine what it would be like if I had one of those in my Tacoma.
I will never use another K&N filter in any vehicle.
Old Jul 6, 2012 | 02:03 PM
That's G's Avatar
I should have inserted the word "dry" in front of "air filter" because that's what I meant.
Old Jul 6, 2012 | 02:10 PM
Jeff92se's Avatar
Red Card Crew
Owner of motordyne advocates an oem filter and chaning it. OEM filters flow very well when clean and terrible when dirty.
Old Jul 6, 2012 | 02:13 PM
dofu's Avatar
20 Year Member
bobistheoilguy air filter comparison
Old Jul 6, 2012 | 02:17 PM
Jeff92se's Avatar
Red Card Crew
That test didn't include the Amsoil Dry filter though.
Old Jul 6, 2012 | 02:34 PM
partyman66's Avatar
Yep.... I remember reading that comparison test a few years ago. It used the old Amsoil foam filter which was an oiled filter.
The newer EA Nanofiber ones are a dry filter.
Old Jul 6, 2012 | 02:37 PM
Jeff92se's Avatar
Red Card Crew
Foam is terrible for filtration.
Old Jul 6, 2012 | 02:38 PM
Jeff92se's Avatar
Red Card Crew
http://www.mkiv.com/techarticles/filters_test/2/
Old Jul 6, 2012 | 03:12 PM
partyman66's Avatar
You know what's interesting about that, is that pretty much all dirtbike and quad air filters are oiled foam. I know both of my dirtbikes use oiled foam ones as do most of my buddies quad filters.
Old Jul 6, 2012 | 03:43 PM
Jeff92se's Avatar
Red Card Crew
Foam doesn't filter but it flows. so since dirt bikes don't get that many hours, they figure you'd get rid of it before the motor wears out. Other filters probably clog too fast so that's another reason to use foam on dirt bikes.
derres
Aug 28, 2015 03:27 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
