TPMS Sensor
Old Jul 28, 2012 | 11:24 PM
cvipgo's Avatar
Originally Posted by Imperial1
Mine does that as well. No idea why either.
your car is 04, tpms sensors batteries are about done, life of TPMS sensor batteries are 5-7 years.- will need new tpms sensors soon.
Old Jul 29, 2012 | 03:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
You guys are having issues with one of your sensors not reading. The beep happens when low pressure is detected, the light after sustained driving with no beep happens when the system can't detect one or more sensors.
Old Jul 29, 2012 | 12:56 PM
Imperial1's Avatar
^^ Well that's good to know lol. It's not that big of an issue since I rarely drive long distances to trigger the light but i guess if i can come across a set of cheap TPMS's i'll pick them up.
Old Aug 13, 2012 | 07:05 PM
ALSHUBCAPS's Avatar
OK here's how it goes, a blinking light on dash means sensor is bad or there is a problem in the receiver in the dash. With a solid light it means you are low on pressure by at least 25%.
TPMS can be reset to any desired pressure that you want to program into the computer. Once you do that it will go off if you are 25% below that setting.
If you have a light going off & it's not low on air you need a tpms tool to test the sensors & then do a reset thru obd2
AL
Old Aug 14, 2012 | 01:19 AM
Mr. Brett's Avatar
Subscribed. I've had a tempermental TPMS light the last few days, too.
Went off the other night after work with the beep. Stopped the car, checked the air, all the tires were inflated to 35 PSI.
Pumped them all up to 40, TPMS light went off. Today, driving, it goes off again with the same beep. Stop, check all tires, still good on pressure. So I'm not sure if one of my sensors is going bad, or the change in weather is messing with them.
Old Aug 14, 2012 | 08:23 AM
ALSHUBCAPS's Avatar
the change in weather will only effect it by changing the pressure, if your pressure reads correct you should have the tpms tested.
Old Aug 14, 2012 | 08:38 AM
sprix's Avatar
I just took my car on a very very long road trip and found that the tpms light kept coming on after I would drive for more than about 1 hour. Whenever I checked, the pressure was between 35-38 psi. I assumed the tires were over-inflated, but now that I am reading this, I guess I might be up for new sensors... 2004 here with just over 90K miles. I guess nothing lasts forever.
Old Aug 14, 2012 | 10:00 AM
DGrantG's Avatar
AL
How do you reset it to a desired pressure?
Old Aug 14, 2012 | 10:01 AM
DGrantG's Avatar
Mine doesn't beep when the light comes on....? Never has and the light has always reset until now...
Old Aug 14, 2012 | 10:02 AM
DGrantG's Avatar
Oh, and is there a way to disable the sensing in the dash so the light doesn't look for the sensors?
Old Aug 14, 2012 | 10:49 AM
ALSHUBCAPS's Avatar
tpms battery life on your year was stated as 5-7 years, chances are your batteries are running low so the transmission is weak &/or intermittent.
Old Aug 14, 2012 | 10:50 AM
ALSHUBCAPS's Avatar
Tpms
you need an obd2 scan tool to do a reset, any good tire shop should have one if they sell tpms
Old Aug 14, 2012 | 12:09 PM
Mr. Brett's Avatar
I've seen extremely cold, damp air mess with them before.
Honestly, these TPMS are ridiculous. They're just one more thing to break on the car. I can check my tire pressure the old fashioned way.
Old Aug 14, 2012 | 12:24 PM
ALSHUBCAPS's Avatar
yes you can check pressure the old fashioned way, if everyone was intelligent & capable of doing that Ford/Firestone would never have had a problem, & tpms would not exist.
Nissan recently came out with a system on some of their 2013 cars that when you reach desired pressure when filling the tire that the horn beeps so you know it is ok without checking.
Whether you like it or not tpms is here to stay & in some states is mandated to be in working order to pass inspection. Overall it is a good thing but people & shops have to understand it in order to diagnose & fix or replace them. At my place we have been doing tpms for over 20 years & we are pretty good at it but still run into headaches.
We did find out that most dealers fix all problems by changing parts not diagnosing problem & they will usually blow you off if you have custom wheels on when a sensor goes bad.
Old Aug 14, 2012 | 12:42 PM
  #30
Mr. Brett's Avatar
Sadly enough, the ones who are too lazy to check their tires themselves are usually the same people that don't know what the (_!_) light is when it comes on on the dash...
