whining noise
Old Aug 5, 2012 | 04:06 AM
options13's Avatar
whining noise
My 2005 G35 has recently been making a whining sound, its very faint, but it's there... its very slight even at idle, you can hear it inside the car when its dead quiet and no stereo or anything.
RPM's control the whine. It happens with both the clutch pedal IN and OUT so i don't think its the transmission. So in turn it happens both in gear and out of gear.
Old Aug 5, 2012 | 09:17 AM
gary c's Avatar
When I see the words "Whining" I think of drive belts, when was the last time you replaced or even checked these? The sound of a worn belt would also increase with RPMs, so that fits and it's unaffected by your clutch....Gary
Old Aug 5, 2012 | 12:26 PM
Mr. Brett's Avatar
Can you pinpoint the whine?
I've heard of whines coming from belts, intakes, and even through the sound system from an improper ground...
Old Aug 5, 2012 | 01:12 PM
partyman66's Avatar
Could be a bearing in the alternator or power-steering pump, or possibly an idler pulley bearing that is on its way out.
Best bet is to get an automotive stethoscope and start poking around under the hood while it's idling and touching stationary parts that are within close proximity to what you suspect may be making the noise. You should be able to hear it pretty clearly if it's a pulley or the belt-driven components.
Old Aug 5, 2012 | 04:11 PM
options13's Avatar
i just replaced my belts not to long ago.. but i do notice the sound did start happening after i hooked up my AMP.. so it might actually be from the stereo, because you can DEF hear it inside vs. outside... gonna try turning my stereo off today and seeing if that helps.
Old Aug 6, 2012 | 12:50 AM
Mr. Brett's Avatar
The reason I suspect your system is because back when I had my system in my Trans Am, I would hear this whine that would increase in frequency with the speed of the motor. I went crazy trying to figure out where it was coming from. Finally, when I was wandering around underneath the car, I happened to bump up against the door panel and realized it was coming from the speaker.
Turns out my Alpine amp I had hooked up to the door speakers had a weak ground. Cleaned the contacts, and I was good to go.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
