Installing Stance Coilovers this weekend
Old Aug 29, 2012 | 06:49 PM
g35dout's Avatar
Guys,
I am installing Stance Coilovers this weekend....can anyone give me pointers before I jump into it? Anything to watch out for? Is it pretty straight forward? Can I contact anyone here if I need guidance since most vendors and Stance is closed on weekends?
Thanks guys
Old Aug 29, 2012 | 06:52 PM
Frankieg35's Avatar
What version do u have?? True rear or oem??
Old Aug 29, 2012 | 07:09 PM
g35dout's Avatar
They are the true rear I believe..the strut and spring are combined in the rear..not separated.
Old Aug 29, 2012 | 07:12 PM
Frankieg35's Avatar
Yeah those are the true rear..
Old Aug 29, 2012 | 07:25 PM
Shanes_G's Avatar
Hey! I will be doing mine too. Hit me up if you need anything5183605478, are you installing the extenders on the rear dampers too? I was thinking about cutting a hole for the rears so I can adjust the damper thru the trunk. It's a pretty easy swap. But if your car is a virgin to moding them bolts are gonna be extremely hard to break free. It is just a direct replacement of the oem struts. Then its just a matter of dialing in your ride hight. Good luck to you
Old Aug 29, 2012 | 07:31 PM
g35dout's Avatar
Thanks brother, I will hit you up...I am trying to search the net to try to find a way to adjust the ride height up and down...I heard it's not as easy as it sounds? Do you know how it's done?
The vendor I purchased them told me to cut the holes in the rears for the adjustment as well...
Old Aug 29, 2012 | 07:36 PM
Shanes_G's Avatar
You just spin the bottom of the strut. But when it's on the car the whole strut will spin . It's easy don't worry about it.
Old Aug 29, 2012 | 07:59 PM
Reds_09's Avatar
Just trollin and I seen this thread.. Thought if get your opinion on a good set of coils for 03 g35 coupe? Not trynna spend more than 1k really... Lookin to get pretty low and flush
Old Aug 29, 2012 | 08:03 PM
Shanes_G's Avatar
What is low to you?
Old Aug 29, 2012 | 08:04 PM
Frankieg35's Avatar
Get a set of used stances..
Old Aug 29, 2012 | 08:12 PM
Reds_09's Avatar
Well I'm not trynna be a pud lol I'm lookin to roll fenders and all. I heard some BC coils were the way to go
Old Aug 29, 2012 | 08:31 PM
SoulGlo's Avatar
have the correct tools.
Old Sep 1, 2012 | 06:35 PM
g35austin's Avatar
I installed my fronts with camber arms last weekend and just finished the rears today on my sedan. Installation is pretty straight forward. Don't mess with the spring pre-loads. Raising and lowering is super easy. Read through the FAQ on stances website for questions on dampening setting and how to raise and lower.
Good luck!
Old Sep 1, 2012 | 09:18 PM
Plur's Avatar
Do you have camber kits? I'm thinking of getting stance coilovers as well for my coupe.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
