P0304 / Valve cover leak
Old Nov 13, 2012 | 10:32 AM
jribbe101's Avatar
Hi Guys,
The other day I noticed my 2003 g35 coupe engine shaking a lot and a weird noise. So i pull out my trusty OBD and discovered a Misfire on Cylinder #4. I am about to go outside and troubleshoot...
1) Coil Packs (can i use ignition coils from a 2008 g35 coupe? what about a 350z?)
2) Pull a plug and see if there is oil on it (if so, leaking valve cover)
If it is a leaking valve cover which I have read from other threads, I wanted to get a used one. Could i use a valve cover from a 350z? I found a cover from a 2004 and 2006 350z for $82. They look identical to what is on my G35.
**UPDATE | Got the 350z cover as the place i got it from said it's an exact match, FYI.
2004 350z valve cover (Driver side)
2006 350z valve cover (Driver side)
Old Nov 14, 2012 | 07:30 AM
tle.88's Avatar
Basically almost everything is interchangeable from the 350z. The driver side valve cover is usually the one that leak. Wonder why it only misfiring on #4 you should look more into it.
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
TNRocker
Sep 21, 2015 08:36 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
UT G35
Sep 3, 2015 03:58 PM
