I Need Help!!
Old Jan 31, 2013 | 02:45 AM
G.Dogg's Avatar
I Need Help!!
Sup guys has anyone ever had an issue with the rear diff slipping, I felt it a couple times driving and today out of the blue all my lights turn on VDC/SLIP/CHECK ENG. i pulled over and started the car again all the lights stayed on cant turn VDC on/off.
If anyone has had this issue please let me know what u think.
Thanks
03 O.G Coupe 6MT Brembos Nismo Custom System too much to list
Old Jan 31, 2013 | 05:58 PM
JBz007's Avatar
Mine has had similar problems in the past but may be different then your situation. If I would really get on my car right after starting it my transmission would not shift and all my lights on the dash would come on. I would have to pull over and kill my car and when I cranked it it ran fine. I guess I wasn't letting my AT warm up enough. Is this similar to what you are experiencing?
Old Feb 1, 2013 | 11:14 PM
G.Dogg's Avatar
I have no problems with my trans its a 6mt CD#2 with 50k miles on it i changed my gear oil for the diff Lucus 75-90 it seems to have helped.. all the lights turned off car runs good so far.
you might want to change out your AT Trans oil
