clutch pedal squeak driving me crazy!!!
Old Jan 28, 2005 | 01:43 AM
nuttyprof's Avatar
OMG, how do you fix this stupid squeak? is WD-40 ok? any body else have this annoying squeak? argh.
Old Jan 28, 2005 | 04:42 AM
DiamondGCoupe's Avatar
my friend is its horrible hes takn it to the dealer in afew hours hoping to have it fixed
Old Jan 28, 2005 | 07:49 AM
Speedoholic's Avatar
G (enie) FUNK ERA
I've had it randomly couple of times - both times it went away just like it came...
Old Jan 28, 2005 | 08:23 AM
JZ39's Avatar
I've been having a problem after adjusting the clutch by 4 turns that the clutch is sticking a bit and not coming up all the way after shifting. It is coming up to the end of the free play area and then sometimes I need to put my foot under it and pop it up the remaining centimeter or so to get it all the way up.
Anyone else have this issue after adjusting their clutch and might this simply be a lubrication issue?
Old Jan 28, 2005 | 09:54 AM
RBull's Avatar
Rated M
clutch squeak
Yes I have it sporadically. I looked at it just before I stored my car 10 weeks ago. The problem seemed to be from slight sideways excessive freeplay in the linkage that connects the pedal to the rod. I'm not sure it can be corrected with lubrication however if it can't and it persists I'll visit my dealer in April and have it fixed under the service warranty converage.
Old Jan 28, 2005 | 09:57 AM
clokwork's Avatar
Cmon Son!
this is weird because my RSX was doing the same thing for a few days and then it went away.
Old Jan 28, 2005 | 03:56 PM
nuttyprof's Avatar
yeah, i adjusted my clutch and may have bent the fork a bit, but i stuck the rataining pin back in so its ok. but that squeak.
so is WD-40 ok for this or do i need some super special car lube? or maybe some K-Y
Old Jan 28, 2005 | 04:02 PM
G35SanDiego's Avatar
I had it about two weeks ago. It dissapeared as fast at it came. WD40 should penetrate well but might not last as long. I would try something heavier. Lithium grease works well. Have had a tub of it for longer than I can remember. I don't even know if they still sell the stuff, really poisoness.
Old Jan 28, 2005 | 04:35 PM
sen_jen's Avatar
Meatshake Enterprise
silicone would work perfect. just turn your radio on, or louder.
Old Jan 28, 2005 | 05:03 PM
RBull's Avatar
Rated M
white lithium grease
I agree with g35sandiego on the white lithium grease. It's available in spray or tube. It's tough and is regularly used in marine applications to resist water/rust too.
Old Aug 31, 2009 | 12:24 AM
Black Acc's Avatar
I started getting this stupid noise too, anyone get it fixed under powertrain warranty? My bumper to bumper warranty just ran out.
Old Aug 31, 2009 | 04:13 PM
parhamm1's Avatar
I was reading this thread earlier this morning trying to figure out what the hell a squeaky clutch sounds like... Get in my car and go out to lunch. When I park I push my clutch in (don't really know why) and I get this annoying squeak!!! I should have never read this thread.... It cursed me.
Old Aug 31, 2009 | 04:17 PM
iamericgee's Avatar
ha ha ! i got the same issue ! silicone spray here i come !
Old Aug 31, 2009 | 04:35 PM
munsterrr's Avatar
i have the same issue....but mine is on the out side...
sounds like those old "parents having sex" squeaky bed thing. it sounds like a poorly lubed....something. mine is def on the outside though
