Creak Noise
Old Apr 15, 2013 | 11:15 PM
sjsharky4's Avatar
Creak Noise
Hi guys,
I know this is a very difficult topic to tackle, but I need help with a super annoying creaking noise. I have had this creak for about 6 months. It happens when I am at a stop, I accelerate (nothing abnormal) and its a creak coming from my rear passenger wheel well. It also happens when I am driving aggressively and the car jolts forward, you can hear the creak. To sum it up, the car creaks when moving forward to back not up and down. Its not my springs or shocks/struts. I took it to a mechanic and he said it might be my brake dust shield? Wiggled it around and couldn't figure it out. ANY IDEAS? :banghead
Here is the video:
http://www.youtube.com/watch?v=mHrel...ature=youtu.be
Old Apr 16, 2013 | 10:10 AM
youloze's Avatar
Is it a creak or a click? Could it be the ever so common axle click?
Old Apr 16, 2013 | 10:35 AM
Lartytiejdke3's Avatar
Sounds like it could be^
Old Apr 16, 2013 | 02:19 PM
sjsharky4's Avatar
It could very well be that. But I really am not sure. I will get a video up after work and see if that helps. Appreciate the input my man.
Old Apr 16, 2013 | 03:38 PM
Blue Dream's Avatar
I drove ttrank's car solo
If it is the dreaded axle click it's a pretty straightforward DIY if you're handy with a wrench.
http://my350z.com/forum/engine-drive...rear-axle.html
Old Apr 16, 2013 | 03:59 PM
youloze's Avatar
Yep, easy fix. Might as well do it even if that's not the problem you are experiencing because it will happen sooner or later.
Old Apr 16, 2013 | 08:57 PM
sjsharky4's Avatar
What do you guys think? Here is the video, it starts after I roll back and then continues to do so from every stop to start.
Old Apr 16, 2013 | 09:15 PM
That def doesn't sound like the axle " click" that I have..
Old Apr 16, 2013 | 09:23 PM
muyrec's Avatar
you're gonna have to lift the rear up and have someone pin point the sound. Only way to find out i'm afraid.
Old Apr 16, 2013 | 09:48 PM
sjsharky4's Avatar
How would you recommend I do this? Put the car on stands and start poking around and seeing if anything is lose or needs replacing?
Old Apr 16, 2013 | 10:57 PM
Blue Dream's Avatar
I'd have to agree with you, the axle click is a lighter, more metallic sound.
Old Apr 16, 2013 | 11:15 PM
Yup^ I can compare the "click" to the sound of having a rock stock in your tire..
Old Apr 17, 2013 | 01:32 AM
shawn's g35's Avatar
same noise happend to me but was coming from the front passenger of my car. after some time searching i found for some odd reason, one of the sub frame bolts was loose..idk y... tightened it up and noise went away..another case that happend to my friends car. turned out to be a sway bar bushing....check if everything is tight and bushings are good..hope this helps..
Old Apr 17, 2013 | 10:27 AM
muyrec's Avatar
yep. Or you can place the jack on the rear differential which is a jack point. You're gonna need a low profile jack to get at it though.
Old Apr 17, 2013 | 10:54 AM
youloze's Avatar
To clarify, it's not a good idea to work under the car using only a jack. You can jack it up using the rear diff but definitely use stands.
