Door Wont Open
Old May 11, 2013 | 11:23 AM
datbeans's Avatar
Door Wont Open
My doors will not open from the outside handles.
I fixed the passenger side very easily, thanks to google. I sprayed a little wd-40 on the latch and it worked like a charm. So if any one has a problem with their door, spray some wd-40 before you take the door panel off like me.
The driver side door still will not open even after i sprayed it with wd-40. I can only open the door with the inside door handle. I took the door panel off and removed my $5 door lock actuator to make sure it was not the reason for the door not opening.
I'm guessing my next move will be removing the many 10mm bolts that hold the steal window plate to the door and just investigate further.
If anyone has solved this problem or has any advice please post up. I am so sick and tired of having to roll my window down to open the door. (especially in the rain )
I cant be the only one with this problem.
Thanks everyone!
Old May 17, 2013 | 05:59 PM
datbeans's Avatar
bump...
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
