Battery tray bolts removal?????
Old May 28, 2013 | 04:22 AM
fatlip's Avatar
I need to remove the bolts for the battery tray. I got the tray out by drilling the bolt heads because they were rusted and stuck. I can drill out whats left but how do i get to the underside where the bolts go through? Ive tried to find a micro fische to see a diagram of the area but i cant find any. Any help will be much appreciated. Thanks.
Old May 28, 2013 | 09:54 AM
gary c's Avatar
I guess we shouldn't ask, why you're trying to remove the battery tray.
Gary
Old May 28, 2013 | 09:41 PM
herrschaft's Avatar
Those bolts aren't that big, did you try a breaker bar at least?
Old May 28, 2013 | 10:41 PM
fatlip's Avatar
The battery acid spilled over and rusted the bolts out and got underneath the tray. So Im going to clean it out and plastidip that area and put the tray back. I got the tray out by drilling the heads off the bolts. What size are the bolts supposed to be? The dealer didnt have the replacements and now i have to go to napa or home depot.
Old May 29, 2013 | 12:08 AM
fatlip's Avatar
Found it. The threading is M8x1.25.
Old May 29, 2013 | 10:42 AM
gary c's Avatar
If there's rust under the tray a better idea is using a paint that will stop rust. Automotive paint stores sell it or I believe PepBoys carries it too. That PlastiDip crud isn't the answer!
Gary
Old May 29, 2013 | 12:55 PM
Therzdae's Avatar
Agree with Gary^
Plasti dip is not going to stop rust, rust does grow if not treated.
Old May 30, 2013 | 02:57 AM
jutn35's Avatar
G35 Coupe
thankyou for updating us with the correct bolt size !
Danielek
May 1, 2022 01:28 PM
magnetism80
Feb 1, 2019 10:00 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
