I Need Help ASAP G Wont Start
Old Jun 3, 2013 | 04:17 PM
Carlos_g35's Avatar
Hi Guys Am New Here, I have A 04 G 35 2D, 2 Months Ago When When I Tried Starting my Car, all you can hear was starter turning, Battery was new had Power, and Car didn't start. All It gave me was The cranking Noise.. again and again...Everytime i Start The Car.. No Check Engine Light.. After A Couple Tries It car started, Someone Told me It was the Throttle Body, So i Change it, and It got fix, and after that my Check Engine stayed ON, And Today I went To start it and It gave me the Same Problem Again, now it Dos'nt Start..
Can It Be Crank Shaft position Sensors? Fuel ,Pump? Or Since i Change the Throttle I need to tune it so the Computer reads it.
Any Help You Guys Can give me ill Aprecciate it, Thanx Carlos
Old Jun 3, 2013 | 04:33 PM
GR6RR's Avatar
http://forums.nicoclub.com/g35-how-t...g-t356397.html
try this to relearn your throttle body.
so many things can be happening though with your problem. It could be anything.
Old Jun 3, 2013 | 09:20 PM
Geewhiz420's Avatar
Crank Shaft position Sensors that was my problem! Driver side.
Old Jun 5, 2013 | 01:17 AM
G'dUpFrmFeetUp's Avatar
Do u hear the fuel pump turning on?
Old Jun 5, 2013 | 02:37 AM
Xet's Avatar
Xet
Please stop Capitalizing every Other word, It makes It extremely Hard to Read and To try To comprehend What you Are saying.
Old Jun 14, 2013 | 04:09 PM
Carlos_g35's Avatar
g35 won't start, I have some codes thanx for helpz
p1148 p1168 p1031 p1051 , my car is giving me problems starting it , some times when I start it motor starts cranking, after a couple tries it starts. I changed the throlle body , it got a little better but its dosnt want to turn on sometimes...I took it to a friends shop and the scanner read those codes any help, would gelp me so much, I kno two of those codes are pre-cat o2 sensors.
Thanks carlos
chinee
Jun 10, 2024 07:48 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jnm07
Sep 5, 2015 01:16 AM
esy
Sep 1, 2015 09:10 PM
poker_lamina
Aug 14, 2015 12:57 AM
