Adjustment on Auto Reverse Window Feature?
Old Jun 10, 2013 | 08:13 AM
Macdady's Avatar
I would like to know if anyone knows about the auto-reverse feature on the power windows? I have 03 G35 and when I try to close the passenger window with the automatic up switch, the window goes all the way up and then opens back up about 4 inches, I then have to use the switch in the normal mode in order to close the window back up. Every time I try the auto-up feature it does this, from what I read the window is sensing something in the way and is retracting back down. Is there a sensitivity adjustment for this feature??........Thanks in advance.
Old Jun 10, 2013 | 11:08 AM
rsingerG35's Avatar
Try to reset your window but it will require you to remove your door panel. Search on the forum or go to infinitihelp.com and look for the DIY section. It may take a few tries so don't give up. If that fails your looking at a new motor and/or a regulator.
Old Jun 10, 2013 | 12:02 PM
KrazySouthG35's Avatar
Both of mine do that...doesn't bother me enough to take the door panels off haha
Old Jun 10, 2013 | 02:04 PM
xnick101's Avatar
Mine does that too. It honestly is not worth buying a new window motor. Just hold it like a normal window switch.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
