Did cluth engagement mod and cruise control no longer works.
Jun 24, 2013 | 10:26 PM
I got really tired of the late engagement points in my car so I did the clutch mod found on this forum and there was a warning that if you turn 3 turns or more you must adjust the cruise control sensor. Well I turned it probably 1 and a half times and my cruise control doesn't work and I wasn't really sure which one was the sensor. I'm pretty confused and was wondering if anybody knows a fix for this and or what the sensor looks like.
Reply 0
Jun 28, 2013 | 09:21 AM
Go to the link below as a reference and to find pics to help you out. But you basically need to adjust your cruise control switch...it must not be getting depressed when you are off the clutch pedal and in gear. It is an easy fix of loosening/tightening nuts on both sides of the cruise control switch and adjusting it so that the clutch pedal bracket is depressing the cruise switch when you are off the clutch pedal. You should be able to find pics in the installation guide to help you better find the cruise switch. Hope that helps.
http://www.rjmperformance.com/instal...tech-page.html
Reply 1
Jun 28, 2013 | 09:33 AM
The cruise control switch it the top one, it should be depressed when the clutch pedal is resting. The switch on the bottom is the one that gets pushed when your press down fully on the clutch pedal so that you can start your car.
Reply 1
Jun 28, 2013 | 05:45 PM
Ok I figured it out guys. Thanks.
Reply 0
