06 Drivers Side headlight issue
Old Oct 26, 2013 | 07:13 PM
260Gcoupe's Avatar
Hey everyone, as you can see I'm a newbie here. Finally got my hands on a DG 06 coupe for a good price after months of looking.
I'm having a problem with my drivers side headlight.(06 OEM headlights) When I have the lights on the drivers side will stay on for about 5-10 minutes then go out. When I turn the lights off and back on it comes on normally. (until it goes out again) There are no issues with the passenger headlight at all.
I've also noticed that if the car is idle with the lights on the drivers light WONT go off. It ONLY happens while driving. I've done a little searching and couldn't find a thread with this particular issue. Prior to taking anything apart I wanted to see if anyone has any ideas. Any feedback is appreciated!
is it a circuit breaker? maybe the ballast?
Old Oct 26, 2013 | 08:56 PM
DKano's Avatar
Most likely it's the ballast either going bad or may have water in it. If you have time to take your headlights out, switch the ballasts from one light to the other and see if the problem starts to happen on the passenger side light then.
Old Oct 27, 2013 | 07:45 PM
Blue Dream's Avatar
I drove ttrank's car solo
Could also be a bad bulb.
Old Oct 30, 2013 | 08:20 AM
Stillen06coupe's Avatar
My guess is the ballast as well. Probably not holding enough voltage under load
Old Oct 30, 2013 | 08:21 AM
Or wiring with the ballast. Was the car ever in a front end collision?
Old Oct 30, 2013 | 05:41 PM
djzachtyler's Avatar
I'm with Blue on it possibly being a bad bulb.
When the ballasts go bad they have a tendancy to blow the headligt fuse.. especially if it has a short internally...
I had a bad ballast on my G when I bought it & had to rely on my fogs until I could replace it cause it kept blowing the fuse
Ludz
Lights
Mar 28, 2016 02:06 AM
R350k5
Oct 1, 2015 08:41 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
