Car/belt is squeeling when it's cold out... not sure the cause of it.
Old Dec 27, 2013 | 02:32 AM
Smitty50's Avatar
I had my engine belt replaced not too long ago. Would it be the ac belt or a pulley that is making the car squeal like a damn pig when it's cold out?
Old Dec 27, 2013 | 01:22 PM
bigc's Avatar
Wings Nation
the belt has probably stretched since it was installed, causing it to squeal until the pulleys warm up. pop the hood and see if the belts deflect too much when you push down on them (use the attached sheets from the service manual for reference). that's likely the culprit.
File Type: pdf
Old Dec 27, 2013 | 01:47 PM
Mr. Samster's Avatar
^ that sometimes happen after replacing belt. Just need a little adjusting and it should be fine happened to me after replacing mine
Greg Huston
Sep 25, 2016 11:36 PM
MR M37s
Oct 30, 2015 08:32 AM
underworld
Aug 6, 2015 01:36 PM
justgotg35
Jul 19, 2015 12:33 PM
