ARCH or Strafe still alive?
Old Jan 19, 2014 | 04:23 PM
Frankieg35's Avatar
Did u trim some of the back of the skirt?? I had to do that to my buddies to get them to sit flush..
Old Jan 19, 2014 | 04:25 PM
Frankieg35's Avatar
Yeah just get nice headed stainless screws and either keep them as is or pick up some touch up paint and paint the heads.. It will look good..
Old Jan 19, 2014 | 04:27 PM
Ogee's Avatar
I was just trying to exhaust every possible method of installing them without bolt heads showing. I guess ill just buy some caps for them and try to disguise it. Thanks! BTW The parts are excellent, next purchase from you will be the carbon fiber duct inserts
Old Jan 19, 2014 | 04:28 PM
Ogee's Avatar
I didnt have to do too much triming on the back side, maybe ill take another look and see if there is a high spot thats pushing it out
Old Jan 28, 2014 | 11:53 PM
G35thrilla's Avatar
for my fiber glass impul skirts i used Name:  fe70af96-6.jpg
they fit exactly into the stock door jamb opening, then just drilled the holes in the fiberglass skirt and screwed them into this butterfly clip. keeps everything pretty tight to the car
Old Jan 29, 2014 | 02:58 PM
Ogee's Avatar
I've got some of those that ill put on each end of the door jam. So you had to buy bolts with a head right? The bolts that came with mine didn't have a head to push the skirt against the car. I'm also going to try 3M VHB 5925 tape, cause the regular 3M super strength body panel tape didn't work. I'll let you know how it goes. Thanks for the tips! Any pics of your door jam by chance?
wckdg35
May 7, 2005 02:51 AM
