g35 intelligent key for stick shift?
Old Feb 7, 2014 | 07:41 PM
joekitch's Avatar
im thinking about picking up a stick shift g35 coupe. sounds like a fun and cheap to own car with good features...
however im noticing some discrepancy between the manual transmission and automatic transmission versions?
even the manual g35 coupes with the pop up nav screen (meaning fully loaded) dont have that little **** thing you turn to start the engine....
and for that matter i dont see it on any manual sedans either...
does the stick shift version just not have this feature?
and furthermore, does the stick shift version no have keyless access? the little button on the door handle you hit to unlock the car if the keyfob is on your pocket
Old Feb 7, 2014 | 08:43 PM
willmkent's Avatar
I bought the auto and have been going back and forth of whether i made the right choice, however don't forget, you can add an aftermarket keyless entry and push button start if you want
Old Feb 7, 2014 | 09:16 PM
joekitch's Avatar
i had considered that, like the ST800 system, although i dont know the install cost
Old Feb 7, 2014 | 09:40 PM
willmkent's Avatar
Some of them seem pretty good! If it were me, I'd try the best car I could and then add options to it providing that they aren't crazy expensive. I'm the guy who is always over worried about the foundation before anything else
Old Feb 13, 2014 | 03:51 PM
Ejgold55's Avatar
Originally Posted by joekitch
cheap to own car
That's what your research led you to believe about a used 6MT and your worried about a key FOB......Good luck
Old Feb 13, 2014 | 05:21 PM
willmkent's Avatar
yea i wouldn't say cheap to own. You have to watch out for a lot of things, there are OC issues, window motors going out, Crank sensors that need replacing, all along with regular maintenance etc etc. This is a great car to own, but you can't skip out of maintenance
arora_g35
Apr 16, 2026 02:52 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Tonka211
Jul 25, 2015 03:22 AM
laksjd84
Jul 24, 2015 05:12 PM
