Correct Belt Size 2005 G35X
May 20, 2014 | 12:13 AM
I picked up a couple belts from Napa 25060465 (1195mm in length) for the drive belt and 25040372 (964mm for the A/C belt).
I took my belts off and measured them to the new belt ffinding out the new belts are bigger. The belts that were on there were Gates micro V belt number 60445 (1148mm in length) and 40350 (905mm in length). Pretty much replacing them same brand belt. It appears my adjuster would be at the very end (or very close to) if I put the new belts on
Does anyone know the correct belt size for a 2005 G35X?
Thanks in advance
Reply 0
Jun 6, 2014 | 09:41 AM
Old post but I didnt see any solution for you. Here are the correct ones. The gates run a little big.
http://www.ebay.com/itm/Nissan-350Z-...-/121339181378
Reply 0
