Air bag recall
Old Jun 23, 2014 | 10:19 AM
Urbanengineer's Avatar
Originally Posted by LoSt180
Maybe you have an actual problem that isn't directly related to the recall portion? Can't expect everything for free.
But this is America;
Land of the FREE after all...
Sorry not the political section. My bad
Old Jun 24, 2014 | 11:51 AM
Lartytiejdke3's Avatar
they didnt fix mine because it was "already fixed in 2011" under the recall.
my question is this
theyre saying its the same issue again. (the old problem has resurfaced)
they arent required to attend to this!?
why issue recalls at all?
bare with me here. trying to understand where theyre coming from
Old Jun 24, 2014 | 12:19 PM
JKL1031's Avatar
They cant turn down a recall or work on safety/restraints. Ask them if they want to get sued.
Old Jun 24, 2014 | 12:28 PM
theyre turning it down due to them fixing it 3 yrs ago, now today the same issue has come up again
Old Jun 24, 2014 | 12:46 PM
Jeff92se's Avatar
Red Card Crew
Plasti-dip it
Old Jun 24, 2014 | 12:48 PM
youre right. it is the end all be all fix it for all car troubles
Old Jun 24, 2014 | 12:55 PM
LoSt180's Avatar
Maybe try from the angle that they did NOT fix it 3 years ago if the exact same problem showed up and the fix is the exact same as what is outlined in the recall.
Old Jun 24, 2014 | 01:23 PM
i have no doubt.
theyre going about it like "well we fixed it once under recall and now its no longer our problem"
obv something wasnt fully and 100% corrected
Old Jun 24, 2014 | 01:37 PM
Jeff92se's Avatar
Red Card Crew
I find it odd that it was fixed and then you had no problems for 3-ish years and now there's a problem.
Assuming you read the recall, is the airbag fault code the exact some one that's described in the recall? Is the fix for this fault code the exact same fix as the recall?
Old Jun 24, 2014 | 02:32 PM
Good point
They're claiming open circuit ???
Old Jun 24, 2014 | 04:01 PM
Jeff92se's Avatar
Red Card Crew
In addition to these mods, HKS | MD | Stillen | H&R | Nismo | HD | Ztube | SPC | Powertrix I suggest an OBDII scanner.
Old Jun 25, 2014 | 12:10 PM
so how does this work? infiniti is saying they fixed the issue prior so they are no longer responsible for the issue. mind you this is a pretty serious safety concern they are blatantly disregarding.
they fixed it, the problem arises again and now they say too bad- we cant help
is this normal?? should i continue to fight this? it sounds like it was never fixed the right way to begin with
Old Jun 25, 2014 | 12:14 PM
rsingerG35's Avatar
They probably have the mind set that they fixed and that you probably could have messed with it. Id contact infiniti via phone or facebook. Maybe call a different dealer if you have one nearby.
Old Jun 25, 2014 | 12:16 PM
Tulsa OK only has one lollll
But yeah I have been-twitter, BBB all of it
Old Jun 25, 2014 | 12:22 PM
  #30
rsingerG35's Avatar
Their quick to respond on fb since millions will see your post.
