ignition key problems/remote start
Old Jul 2, 2014 | 05:21 PM
an2ane's Avatar
First im new here I have a 2003 g35 coupe 6mt and im having problems turning it on, I replaced the transponder key and at first it would turn on fine, then after a while it turns out its the whole key cylinder, so sometimes i park downhill and turn it by popping the clutch out, my question is since the car stays on after i pop the clutch out I was wondering if i can install a viper alarm remote start system to start it up and go, will this leave my car on or will it turn off after i drive away?
Old Jul 3, 2014 | 07:33 PM
Jonlex99's Avatar
You should be fine.. The way the viper will work. Once you start the car via the key fob you will enter the car and, turn the switch to the on position step on the brake and the car will stay running till you turn the key to the off position.. That been said I would subjest you have your starter tested... Good luck..
Old Jul 5, 2014 | 02:30 PM
an2ane's Avatar
The starter is good battery and everything I just need to replace the nats antenna but I have no idea were to take it to fix it.
chinee
Jun 10, 2024 07:48 PM
FRUG35
Aug 9, 2015 07:55 AM
D1dphresh
Aug 7, 2015 06:10 PM
.cakestar
Aug 4, 2015 09:05 PM
