05 g35 overheating!!
Old Jul 28, 2014 | 03:15 PM
Girldriven09's Avatar
Hey guys , bought my 05 coupe in April of this year. Had it for about 3 weeks and was waiting in line at a drive thru when my temp started rising, I immediately pulled into a space and checked my overflow tank.. It was empty.. I filled it with coolant and didn't have a problem since . About two weeks I was sitting at a red light and my temp started rising again. Pulled it over shut it off and checked my coolant, it was fine. I drove it home(had to pull over and shut off the car several times due to temp rising) and I figured it was the thermostat. Replaced the thermostat and filled the coolant in the overflow and the actual radiator . Took it for a drive and it got hot once again. I figured there was air in the lines from having the system opened. I read instructions on how to burp it, followed them. Sat my car on a hill filled my radiator left the cap off and started the car, turned my heat on full blast and let it run till it stopped bubbling . I did not have heat at first, after about 10 min I did . Drove it that night for about an hour and it was fine. Took it out the next day and the temp would rise a little above half way then go back down. Did this about 4 times . I tried burping it again and I again do not have hot air coming out of my vents. Do I still have air in my lines or is this something else? It's been driving me nuts not being able to figure it out any help would be awesome! (Yes I have checked my fans!)
Old Jul 28, 2014 | 03:37 PM
ScraggleRock's Avatar
Sounds like you still have air in the lines if you aren't getting heat. Have you felt the bottom radiator hose when the car is hot? If the bottom hose is cool when the engine is hot, your thermostat isn't opening (this can happen even if its new)
Also, have you pressure tested the radiator and cap? Sounds like you could have a hairline crack in the radiator or the seal on your cap could be bad. Check on parts surrounding the radiator for dried up, rust colored "spray" spots.
Old Jul 28, 2014 | 04:30 PM
gary c's Avatar
He's probably correct about you're still having air in your radiator system and it wouldn't hurt to have the system pressure checked. What I disagree with is the color of fluid, it should be green (color of radiator fluid) not rust!
Gary
Old Jul 28, 2014 | 04:45 PM
Gary
It SHOULD be, but not everyone maintains their vehicles the way they should, and it usually dries in a rust color.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
yassy
Aug 3, 2015 12:24 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
