G35 auto trans wont release the key in parking
Aug 20, 2014 | 10:03 PM
Hi im having a problem with my 03 g35 coupe automatic .. When i push the clutch to parking it wont realease the key .. Till i give a lil push after it still on park and i hear a click wich then release tbe key .. Do anybody know what would be the problem and how to fix? I will apreciate it thanks.
Reply 0
Aug 20, 2014 | 11:11 PM
Simply first, you may have to just wiggle the key to make sure it is for sure in the off position, something you have to get a feel for with all keys.
Next, make sure you hold the button all the way into park and wiggle the shifter a little bit.
Third, it could be a guide under your driving shifter that has been taken out before and incorrectly put back.
PS. AUTOMATIC TRANSMISSIONS DO NOT HAVE CLUTCHES. Automatic transmissions have torque converters (fancy way of saying torque losers) that utilize electronic shifting. Clutch levers at the feet disconnect power to the transmission from the engine!
You do not call that ball in your right hand a clutch , you call it a shifter.
Reply 0
Aug 21, 2014 | 05:58 PM
Lmao aihh my bad anyways i took to the mech today and he said it was something about a adjust under the shifter cover .. Do you know whats the adjust looks like? If there is a pic it would be greats thanks
Reply 0
Aug 22, 2014 | 12:23 AM
Quote: Lmao aihh my bad anyways i took to the mech today and he said it was something about a adjust under the shifter cover .. Do you know whats the adjust looks like? If there is a pic it would be greats thanks
You can pop up your shifter by pulling down on the metal piece of the boot, pulling out the metal holding pin, and pulling the shifter off.
See Wrathernaut's DDin installation guide for info on how to so it.
Reply 0
