help transmission
Old Jan 15, 2015 | 08:52 AM
andrewx373's Avatar
help transmission
How do I take my transmission out step by step
Old Jan 15, 2015 | 09:01 PM
bprice92's Avatar
Automatic
REMOVAL
CAUTION:
When removing the transmission assembly from engine, first remove the crankshaft position sensor
(POS) from the transmission assembly.
Be careful not to damage sensor edge.
1. Disconnect the negative battery terminal.
2. Remove engine cover.
3. Remove A/T fluid level gauge.
4. Remove engine under cover with power tool.
5. Remove front cross bar with power tool. Refer to FSU-8, "Components"
6. Remove exhaust front tube and center muffler with power tool.
Refer to EX-3, "Removal and Installation" .
7. Remove three way catalyst. Refer to EM-24, "Removal and
Installation" .
8. Remove rear propeller shaft. Refer to PR-5, "Removal and
Installation" .
9. Remove control rod. Refer to AT-236, "SHIFT CONTROL SYSTEM" .
10. Remove crankshaft position sensor (POS) from transmission
assembly. Refer to EM-28, "Removal and Installation" .
CAUTION:
● Do not subject it to impact by dropping or hitting it.
● Do not disassemble.
● Do not allow metal filings, etc., to get on the sensor's
front edge magnetic area.
● Do not place in an area affected by magnetism.
11. Remove rear cover plate. Refer to EM-28, "Removal and Installation"
12. Remove starter motor. Refer to SC-19, "Removal and Installation"
13. Remove rear plate cover from converter housing part. Refer to
14. Turn crankshaft, and remove the four tightening bolts for drive
plate and torque converter.
CAUTION:
When turning crankshaft, turn it clockwise as viewed from
the front of the engine.
15. Support transmission assembly with a transmission jack.
CAUTION:
When setting the transmission jack, be careful not to allow
it to collide against the drain plug.
16. Remove rear engine mounting member with power tool.
17. Remove engine mounting insulator (rear).
18. Remove air breather hose. Refer to AT-273, "Removal and
Installation" .
19. Disconnect A/T assembly harness connector.
20. Remove fluid cooler tube and A/T fluid charging pipe.
21. Remove O-ring from A/T fluid charging pipe.
22. Plug up openings such as the fluid charging pipe hole, etc.
23. Remove bolts fixing transmission assembly to engine with
power tool.
24. Remove transmission assembly from vehicle with a transmission
jack.
● Secure torque converter to prevent it from dropping.
● Secure transmission assembly to a transmission jack.
MANUAL
REMOVAL
1. Disconnect battery negative cable.
2. Remove catalytic converter stay mounting nuts and bolts, and
then remove exhaust mounting bracket. Refer to EX-3,
3. Remove nut connecting catalytic converter to exhaust manifold, and then remove catalytic converter and
exhaust front tube as one unit.
4. Remove propeller shaft. Refer to PR-5, "Removal and Installation" .
5. Remove control rod mounting bolts and then separate shift lever
assembly from the control rod assembly.
Edition: 2004 September 2005 G35 Coupe
6. Using a suitable tool, release claws and separate console boot
from center console. Refer to IP-11, "Removal and Installation" .
7. Remove hole cover mounting bolts and then separate hole
cover from the floor panel.
8. Separate control lever boot from guide plate.
9. Remove guide plate mounting bolts and then separate shift lever
assembly from the shift lever housing.
10. Remove clutch operating cylinder mounting bolts and then separate heat insulator and clutch operating
cylinder from the transmission case. Refer to CL-11, "Removal and Installation" .
11. Remove crankshaft position sensor (POS).
CAUTION:
● Do not subject it to impact by dropping or hitting.
● Do not allow iron dust, etc., to get on the sensor's front
edge magnetic area.
12. Disconnect neutral position switch and back-up lamp switch.
13. Separate heated oxygen sensor 2 wire harness, crankshaft
position sensor (POS) wire harness, back-up lamp switch wire
harness and PNP switch wire harness from the transmission.
14. Remove starter motor. Refer to SC-19, "Removal and Installation" .
15. Set transmission jack to the transmission.
CAUTION:
When setting transmission jack, be careful so that it does not contact with the switch.
16. Remove rear engine mounting member. Refer to EM-104,
17. Remove engine and transmission mounting bolts with power
tool.
18. Remove transmission from the vehicle.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
