3rd brake light/spoiler light are out
Used 2005 G35 coupe 3rd brake light and spoiler light are out.
I'm new to this car hoping you all can help me in troubleshooting why this is not working.
FYI: I have no idea of what past owner has done to car or what changes could have been made.
Please help is this a common problem.
Well, for one thing, the car should have 1 light, and not both. So the fact that you have a 3rd brake light on the rear shelf, and a light in the spoiler means that a past owner added the spoiler.
Now, if they wired it up is another question. So without having the car in front of us, it's tough for us to see if the past owner cut the wires to the original light and wired the 3rd brake light, or never wired the 3rd brake light and the original light has burned out (common issue with G35's)
So basically step one is to open the trunk and see if you have wires going to the 3rd brake light.
BTW, a lot of ebay aftermarket OEM wings had crappy 3rd brake lights that burned out fairly easily. So partof your investigation will be to find out of your wing is OEM or an OEM-replica and if holes were drilled into the original trunk, or the owner swapped trunk lids.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
