G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   G35 coupe rear driver's quarter panel rust opinions (https://g35driver.com/forums/g35-coupe-v35-2003-07/446827-g35-coupe-rear-drivers-quarter-panel-rust-opinions.html)
sman217 Jan 28, 2015 03:45 AM
need feedback regarding pricing, and options to fix my rust situation. have rust on driver side wheel well in the lip of the quarter panel. its starting to emerge from the paint, but hasn't hit the front, (face) of the quarter panel. all help is grateful!
https://cimg1.ibsrv.net/gimg/g35driv...f0a0826536.jpg
https://cimg2.ibsrv.net/gimg/g35driv...003d287446.jpg
im located in cincinnati ohio, anybody know any shops that can fix this kind of gig in the near 200 mile vicinity i will be interested.
sman217 Jan 29, 2015 12:47 AM
Bump
aaron3719 Jan 29, 2015 05:58 PM
You got a MAACO nearby? i'd go there. Mine's rusted too like yours but at bottom of driver's door which looks pretty ugly...
denwalt87 Jan 31, 2015 10:16 PM
Any body shop in your area can fix it. They will either just sand or grind through the rust and take it down to bare metal and then refinish. As stated above MAACO could do it, probably pretty cheap, but I haven't heard a lot of good remarks about long term paint work lasting through them. Might be different in your area though. if you are lucky they might be able to burn it in just in the wheel well area and not touch the outer qaurter paint at all
Mr. Brooks Jan 31, 2015 10:33 PM
Try some Naval Jelly.
Urbanengineer Jan 31, 2015 10:57 PM
Cincinnati MAACOs get the job done. Give them a call they are offering low rates just got my honda repainted.
willmkent Feb 10, 2015 07:13 AM
Hey man, I have the same problem happening to mine, I went to 3 reputable body shops and got several quotes. To grind fix and paint I was quoted about $1100 with no work warranty because the shops don't warranty rust work unless the entire panel is replaced. With that being said I got a quote to do the entire rear quarter (not worth it) for 4,000. Maaco quoted me 500 bucks but as other users said, they are the McDonald's of body shops, instant gratification but not really good for you lol. Please keep me updated with what you do as well because if you end up getting a good deal I'll take my car there too, hell I live in Michigan, maybe we can find a place to do a 2 deal. Below is a picture of mine
http://i1331.photobucket.com/albums/...psnyqa7ddf.jpg
Mr. Brooks Feb 10, 2015 08:57 AM
Are you even listening
I guess you guys didn't read my post so, I'll say it again. TRY SOME NAVAL JELLY. Naval jelly is a rust remover. It removes rust, dirt, grime, and, oxidation from any surface. It was developed to clean Navy ships. Don't believe me, google it. I keep a bottle of this stuff. I use it to keep my rims looking new and its way cheaper than a body shop. Also from the look of those pics I'd get those fender lips rolled or trimmed.
willmkent Feb 10, 2015 04:35 PM
Hey Mr.Brooks, what exactly should I do with this. mine is starting to get worse, how is the naval jelly going to help stop and prevent further oxidization ??
Im curious because i believe you, please let me know
Thanks
Mr. Brooks Feb 10, 2015 10:56 PM
Here's what you should do
First purchase some Naval Jelly (rust remover) from your local Walmart or auto store (Walmart may be cheaper). Next wash and rinse the area to be treated. With the one dollar paint brush you've also brought from Walmart liberally apply the Naval Jelly and let sit for 10 to 15 minutes. Next rewash and rinse the treated area. Reapply if necessary. Also wear gloves when using Naval Jelly and throughly clean the paint brush for future uses.
From the looks of these pics Naval Jelly should help a lot these areas don't look that bad. Like I said, I use it to clean my rims at least once a year (especially after the winter) and it has NEVER let me down. It cost no more than 5 bucks and can be used on many different metals WITHOUT damaging the metal or painted surfaces.
vrracing Feb 10, 2015 11:50 PM
Locktite Naval Jelly is good for removing rust before refinishing. Your rust looks pretty light and if you don't want to spend a lot of money you might consider another Locktite product Extend that converts the rust to a stable, paintable finish.
Good luck!
willmkent Feb 11, 2015 06:55 AM
Thanks guys, I plan do give this a try as soon as weather permits, I may sand down the area use these products and then try to respray the area a bit
InfinitiGeeX Aug 10, 2015 07:32 PM
I have this exact issue but in the rear. Should I just sand it and spray rust converter, prime, and paint? Or just use Por 15 / rust Bullet?
Thanks
SlowG_Coupe Aug 24, 2015 08:07 AM
I have the same issue, I was thinking of sanding it, priming then touch up paint. Good idea anyone ?
© 2026 MH Sub I, LLC dba Internet Brands
