Gas guage broken
Old Feb 22, 2019 | 08:50 PM
OhioGman's Avatar
G35 Coupe , building for FI
seen a youtube video where you take the furl pump out on each side clean the contacts on the floats using a qtip and should work .. if not then need a new fuel pump assembly for each side i thing..
Old Feb 23, 2019 | 06:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Easier way is to just measure resistance across pins 2 and 5 on the pump main harness and see if the resistance value is between 4-80ohms depending on fuel level, sub harness on the other side should be 3-43 ohms. If the resistance is wrong then the problem is the floats sending the wrong fuel level to the combination meter, if the resistance is correct then it's highly likely the combination meter is bad, very slight chance that the wiring between the two is damaged.
No tools needed except a digital multimeter, no tearing apart stuff needlessly and risk getting gasoline on interior components, rear seat removal takes all of about 10 full seconds start to finish.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
Hogbone
Sep 28, 2015 06:44 PM
