Stock 19 rays with 275 tire and 25mm spacer .. will it work?
Old Feb 25, 2015 | 03:52 PM
Dfel05G35's Avatar
Anyone running the stock 19 rays with a 275 tire in the rear and 25mm spacers. I plan on doing this without lowering the car. Wondering if there would be any rubbing. I know people are running 25mm in the back on the stock tire side without any issues.
Old Feb 25, 2015 | 04:27 PM
Urbanengineer's Avatar
Those rear sizes would be 1.15 inch wider than stock tired and would not fit without a profile shrinking. What's the profile?
Old Feb 25, 2015 | 04:31 PM
Dfel05G35's Avatar
Havent bought the tires yet. I have my winter set up now but my summer set up rears need to be replaced. I plan on adding spacers so trying to figure out the widest tire I can go with on the rear without rubbing issues.
The store tire size seem to leave a bit of the edge of the rim exposed. Thought a bigger size tire would be no issue... with whatever profile needed to ensure the circumference of the tire remains the same as stock.
Old Feb 25, 2015 | 05:07 PM
Havent bought the tires yet. I have my winter set up now but my summer set up rears need to be replaced. I plan on adding spacers so trying to figure out the widest tire I can go with on the rear without rubbing issues. The store tire size seem to leave a bit of the edge of the rim exposed. Thought a bigger size tire would be no issue... with whatever profile needed to ensure the circumference of the tire remains the same as stock.
Use the tire rim calculator here on the site to see what you are working with
Old Feb 25, 2015 | 05:11 PM
Dfel05G35's Avatar
I checked what the replacement size in 275 were and I need a 275/30/19 tire which would only be a -0.4% size difference which I am ok with. I was more concerned about the extra width and 25mm space causing the tire to rub on the rear fenders. Don't want to have to roll the fenders.
Old Feb 25, 2015 | 05:46 PM
Deepdiver's Avatar
for your reference, I run 275/35/19s in the rear, no spacer. No rub.
EnCr1pt3d
Jul 29, 2015 03:35 AM
realtalk21
Jul 20, 2015 09:07 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
mushu
Jul 15, 2015 03:55 PM
