need help please
Old Mar 5, 2015 | 07:19 PM
elf83's Avatar
need help please
I have a 04 g35 coupe no modz exept a takeda intake. My car started buckling and hesitating one day so I took it to the mechanic who pulled a p0327 knock sensor bank 1
And system to rich p0175
Any how the mech. Changed knock sensor, still no change,changed sparkplug still no change,and changed new throttle body. Still no change exept for in my wallet. Im 700 dollars short and whith the same problem
I did the ecu reset, and the relearn.
The car seems to have lost allot of power and slow. Sounds like a train when i drive the car and does not go past 70mph. Please help. Thanks in advance.
Old Mar 5, 2015 | 07:32 PM
DigitalDeviant's Avatar
Have you had a compression test done? Sounds like you may have a dead cylinder.
Old Mar 5, 2015 | 08:26 PM
elf83's Avatar
No I havent had one done.
Hope its not because it would be the wort car ever.
Old Mar 6, 2015 | 11:35 AM
Urbanengineer's Avatar
No I havent had one done. Hope its not because it would be the wort car ever.
Get one done. This will give you more answers then you will need to know.
Old Mar 7, 2015 | 11:07 AM
NepTuneZ's Avatar
I have p0327 all the time and probably will not change the knock sensor till lord knows. Hmm have you checked for vacuum leaks or your maf sensor? I had infiniti in greensboro, nc do my spark plugs (anyone in nc dont ever go there i got tired of them harming my car then helping it, i started fixing the car myself) they ended up cracking the white part of spark plug which gave me a hell of a problem whenever i tried to step on it. I changed a whole new set of plugs and the car was fixed. Maybe double check the work the guy did on the spark plugs, and or the coil packs. I by all means am no expert just letting ya know the experience i been through. Goodluck brother i feel your pain i too have a 04 and stuff after stuff just keeps breaking down one after the other.
Old Mar 15, 2015 | 02:47 PM
elf83's Avatar
here are my codes
Fault log report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Current Fault Log
P0300: Random/Multiple Cylinder Misfire Detected
P0327: Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0175: System too Rich (Bank 2)
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
I know for a fact that p0327 is knock sensor harness, but will that help the other codes?
