Wheel/tire specs enabling my VDC?
What was your OEM tire setup? 18" or 19"
You can plug tire sizes in here to see the difference
http://www.sizemytires.com/calculators/compare
Im not sure tbh, got it as 3rd owner.. it had sport 18s on it when I got it..
I bought the 235/45/18 in fronts.. checked all tire calculators, 275/35/19 and 235/45/18 diameter/height are within 3% , i hope im right lol
235/45/18 is closer only 1/2" in difference between front and rear. That should work.
I think if you check the driver's door, where the recommended air pressure are, it will tell you. The sticker will be either for the 18's, or the 19's, but not both.
Not 100% sure, but i think they "customize" those decals for the OE setup.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
