Weather strips issue?
Old Jun 10, 2015 | 01:01 PM
feli_s17's Avatar
I have an 05 g35 and when i drive it on the drivers side you can hear air coming through on the top left of the door. I'm thinking it might be that top weatherstrip but I'm not sure. What do you guys think, I'd really apreciate some feedback, thanks !
Old Jun 10, 2015 | 05:35 PM
Urbanengineer's Avatar
Pull it around and lube it up to make sure the window slides in well, and then check again. After that GL.
Old Jun 12, 2015 | 08:06 AM
feli_s17's Avatar
Thanks !
Old Jun 13, 2015 | 02:29 PM
rsingerG35's Avatar
More than likely the window is out of adjustment as the window can be adjusted to move inward and outward. You will also get leaks if your window isn't parallel with the weatherstrip which is another adjustment.
Old Jun 14, 2015 | 01:17 AM
Lartytiejdke3's Avatar
from now on, just drive it from the passenger side
Old Jun 14, 2015 | 05:47 AM
tha_ape's Avatar
G35 6MT Coupe
A long time ago I heard of a trick to repair weatherstripping, but I've never had the cajones to try it.
Basically you open the door, put silicone on the weather stripping where you need it, IMPORTANT: then apply vaseline to your window, close the door and let it set. Open the door (hopefully the vaseline worked!) trim the excess and viola! Jobs done.
As I said, I was always too scared to try it, but it seems like it would work.
Old Jun 14, 2015 | 06:36 AM
HypedAndy's Avatar
i have the same problem. i hear air through high speeds and tiny bits of water dripping in from hard raining (not light)
mike730
Jan 12, 2018 04:25 PM
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
