Cruise Control
Old Jun 27, 2015 | 08:01 PM
merkg35's Avatar
Cruise Control
Hey guys n gals, I feel like I am an idiot for posting this but how do you set cruise control on a 2006 G35 Coupe 6-spd Manual transmission. I turn cruise control on and then press the button up to set it but nothing happens. Am I doing something wrong or does is the cruise control malfunctioning?
Old Jun 27, 2015 | 09:00 PM
CanadianBird's Avatar
Owner's manual?
Old Jun 27, 2015 | 10:11 PM
tha_ape's Avatar
G35 6MT Coupe
Turn it on with the button on the right of the steering wheel ("cruise" light turns on on the right of instrument cluster).
Click the rocker switch up or down (forget which). Another light comes on.
Sounds like you're doing it right though....
Old Jun 27, 2015 | 10:25 PM
wuzz-upp's Avatar
On my 2003, once you turn the cruise on, the upper toggle button is pushed down to set the speed. Once the speed is set you can in crease the speed by pushing up on the same toggle button and decrease by pushing down while the cruise control remains on. Once you use the brakes, the cruise control will disengage, you can push the upper button up and the cruise control will resume to the last speed selected. To turn the cruise off push on the same button used to turn it on. Hope this helps. Hope this helps.
Old Jun 28, 2015 | 05:26 PM
matt0323's Avatar
Sounds like your cruise control f**ked up bro
Old Jun 28, 2015 | 06:18 PM
wuzz-upp's Avatar
Not necessarily, it just sounds like he is not operating the cruise control correctly. He hasn't responded yet since his original post, hopefully we will get an update soon.
Old Jun 29, 2015 | 06:59 AM
saywat?'s Avatar
Down Is to set up is to clear it
Old Jun 29, 2015 | 10:06 AM
wuzz-upp's Avatar
I can only speak for the 2003 coupe which is what I own, but I would venture to say it is the same than the 2006 posted. Not sure what you mean by clear it.
Toggling down sets the initial speed. Toggling up after the initial setting, increases the speed (Accelerate) and resets that as the new speed selected. Toggling down after the initial time decreases the speed (Coast), and resets that as the new speed selected. If the brakes are applied, cruise control remains armed, but disengages. If you toggle up after braking (Resume), the car will speed up to the last speed selected.
Old Jun 29, 2015 | 12:34 PM
Spartan268's Avatar
Press down, not up to set the cruise control
Old Jun 29, 2015 | 01:15 PM
saywat?'s Avatar
From the owners manual. Wow didn't kno it could do more than jus set n reset lol
Old Jul 6, 2015 | 07:28 PM
merkg35's Avatar
Sorry it took so long to reply, went on a vacation, had to drive from L.A. to Denver with no cruise control... FML.
I know i am operating it correctly and will have to take it in to infiniti to take a look at it.
The light is not blinking which suggests that it isn't malfunctioning, according to past posts.
I read that owners manual like 3 times and my buddy has the same year and model and his works just fine. I'll post what the issue was as soon as i get it back!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
