Power seat issue?
Old Sep 5, 2015 | 10:27 AM
zcherub's Avatar
Power seat issue?
So I recently noticed that my driver's side power seat works (tilt, height, forward/backward - all working), but the memory feature & the button on the rear of the seat (that allows rear passengers out with a push) aren't responsive at all.
I've searched, and have only find folks with the manual power seat control issues, but not the preset & rear buttons only. Are these on a separate fuse/harness I should check?
Thanks in advance for the suggestions.
Old Sep 5, 2015 | 09:39 PM
wuzz-upp's Avatar
Peaked my curiosity, my 2003 service manual shows my year does not have a memory feature. I looked at a 2006 to see and it does have a memory feature. What I can tell you is that I read that if the battery is disconnected, the stored memory gets erased and has to be reset. You don't say what year your vehicle is, but I would recommend you check out the service manual for your specific year and follow the instructions in the SE section of the manual.
Old Sep 10, 2015 | 12:03 PM
Elpuas3000's Avatar
The problem is the seat control module, you need a new one, if you get it from the dealer is going to be 600 dollars if you are able to find it in the junk yard it will provably be 200 or less.
derres
Aug 28, 2015 03:27 PM
Danielek
Aug 11, 2015 09:33 AM
wuppiedog
Aug 7, 2015 11:16 AM
slider_ua
Jul 29, 2015 04:17 PM
