05 6MT Notchy gear engagement.
Old Dec 25, 2015 | 07:00 PM
partyman66's Avatar
Originally Posted by avion
Well Guys, The "EXPERTS" recommended that I try AMSOIL 75-90 GL4 gear oil. The results I must say is an improvement. Much better then Nissan oil or the REDLINE MT85 gear oil. It still does not shift like a Honda or a Porsche, but I guess I have to live with it.
Thanks Again for all your inputs.
Most Hondas are front wheel drive. The gear shifter doesn't go straight into the gearbox like it does in a RWD car so a lot of that mechanical feel is absorbed by the linkage.
Old Dec 25, 2015 | 07:23 PM
saywat?'s Avatar
U guys don't appreciate the f1 experience Infiniti provided?
Old Dec 25, 2015 | 11:56 PM
partyman66's Avatar
F1 circa 1988? That's when paddle shifters started taking over for pure manual gearboxes. Lol.
Old Dec 26, 2015 | 03:19 AM
dofu's Avatar
20 Year Member
Originally Posted by andrewvk
just because its working fine doesnt mean you should leave old fluid in there.
lol holy **** thats horrible.
i change out my manual trans fluid every season. i do road racing and drifting though. but i would definitely not listen to this guy.
Actually, in his case, a lot of mechanics would not want to change out the fluid. Reason being that something might actually be messed up but it's holding on just fine still. Draining the fluid will move things around and something can fall apart.
It's like old tires which have not seen an alignment track for a long time - to prolong the life of those tires, you are better off leaving them alone.
I'm not saying it's necessarily the best thing to do, it just depends on how much money you want to spend.
Old Dec 26, 2015 | 03:20 AM
dofu's Avatar
20 Year Member
I would avoid anything Redline for the G. This car seems to like Motul a lot though.
Old Dec 26, 2015 | 03:36 PM
partyman66's Avatar
This theory doesn't make any sense at all for a MT. I think you're referring to flushing an AT that has never had service done on it since it can dislodge debris which then plugs up fluid passageways. In a MT the oil basically just sits in the bottom of the transmission housing and the gears dip into it as they spin. It's not pumped up anywhere like in an AT so there are no oil passages to be blocked by dislodged debris or buildup and most certainly nothing mechanical getting moved by the fluid change in an MT.
Old Dec 26, 2015 | 05:03 PM
saywat?'s Avatar
I don't understand how people can still be using the terms flush n drain n fill interchangeably.
Old Dec 26, 2015 | 05:11 PM
partyman66's Avatar
Nobody did that here. The only mention of a flush anywhere here aside from me mentioning it with an AT (where a flush is a legit different service from a fluid change), and the other guy mentioning flushing his clutch fluid which is also a legit thing.
Old Dec 26, 2015 | 05:38 PM
saywat?'s Avatar
Dofu is referring to a flush I believe. My understanding is other guy talking bout drain n fill
VQ702
Nov 17, 2015 01:46 PM
Beauzeus
Oct 9, 2015 04:14 PM
Jay123
Sep 28, 2015 08:42 PM
haninja
Drivetrain
Nov 21, 2007 10:54 AM
haninja
Nov 21, 2007 08:49 AM
