Engine Knock?
Old Feb 23, 2005 | 02:24 PM
IvoryGT-V's Avatar
Engine Knock?
Hey guys imma new to this forum. I have a 04.5 G 6 speed. Has anyone experienced a engine knock while in idle? It seems to kinda sputter at idle only....
Old Feb 23, 2005 | 02:25 PM
DiamondGCoupe's Avatar
Get some fuel injector cleaner
Old Feb 23, 2005 | 02:30 PM
patrickwong's Avatar
aren't fuel injector cleaners bad for your car?
Old Feb 23, 2005 | 02:32 PM
IvoryGT-V's Avatar
I just go my first oil change it has 4900 miles on it
Old Feb 23, 2005 | 02:33 PM
OK, take it to the dealership and have them clean out your fuel injectors..
wow 5000 miles, are you using 91+ Octane gas?
Old Feb 23, 2005 | 02:36 PM
IvoryGT-V's Avatar
I use premium only...
Old Feb 23, 2005 | 02:37 PM
IvoryGT-V's Avatar
It runs fine and all and there are no warning lights on..
Old Feb 23, 2005 | 02:59 PM
g35cas's Avatar
Bad Gas?
Sorry, but no joke. We had a run of bad gas in my area last summer. Water got into an underground tank at a gas station and messed up quite a few cars. Just a guess.
Old Feb 23, 2005 | 03:39 PM
Eh that would cause a little more than a slight knock in the engine.
Old Feb 23, 2005 | 05:34 PM
madchef's Avatar
I would say the sputtering is not normal. I would have it checked out.
Old Feb 23, 2005 | 05:36 PM
jayco's Avatar
i'd also get it looked at. could be your fuel injectors as people have mentioned. i'm just guessing here, but it could have something to do with your MAF sensor. do you have anything aftermarket on your intake? have you changed your air filter recently?
Old Feb 23, 2005 | 08:45 PM
marshman's Avatar
I have the same problem with my 04.5 6MT. I think the knocking sound is from the shake of the clutch due to random jumps in idle vibrations (engine sputter maybe?). Also, my check engine like went on yesterday too...which i think usually means a problem with the emissions. I have a K&N filter installed that i'm going to swap out for OEM this weekend. Hopefully this will help.
Old May 13, 2005 | 10:51 AM
JohnG35C's Avatar
Idle misfire.
I am having the same problems with my 04 6mt as well. I have put fuel injector cleaner yesterday. The problem got alittle worst when I went from the stock intake and swapped for the z-tube. Any Info on this is appreciated.
