Window Probelm
Old Oct 4, 2016 | 03:15 PM
slow's Avatar
Window Probelm
Hey guys, I just recently bought an 06 G35 and the window started to act up as soon as i drove it home and parked it in my driveway. The window wont go up or down unless i slam the door shut a few times. And when it does go down it will go halfway and stop. Then i have to slam the door a bunch of times until it goes back up. But when the window motor does actually move it moves at a normal pace. Is it the window motor or the switch that is the problem!?!?!?! HELP
Old Oct 4, 2016 | 04:09 PM
Urbanengineer's Avatar
Read the service manual http://psedog.com/cars/fsm/g35/
You need to reset the window motor. A negative of having automatic raising windows.
Old Oct 4, 2016 | 04:20 PM
SoulGlo's Avatar
buy the new window motor!
next up to go - Door locks - Not that big of a deal i always left the car unlocked
Old Oct 4, 2016 | 04:40 PM
davewes's Avatar
Welcome to G35 coupe ownership. I just had to replace both the window motors at 36k miles on the odo. Rock auto has a great price on them. It's not a bad install. Search the forum for a DIY.
Old Oct 4, 2016 | 08:13 PM
partyman66's Avatar
Before you go replacing the motor, take the stock one out, remove the main shaft drive and clean out the carbon buildup in there, grease the end of it and reassemble. I did that on my driver's side window motor when it stopped working 4 years ago and it has worked perfectly since then.
Old Oct 6, 2016 | 11:06 PM
slow's Avatar
Thanks guys i bought the motor and installed it myself. It went smooth, a pretty simple process. But, it worked my window is working perfectly now THANKS!!!!
Old Oct 7, 2016 | 12:26 AM
davewes's Avatar
Good to hear man.
Old Nov 13, 2016 | 11:01 PM
Duinit's Avatar
Have a driver's window doing the same thing. Motor will work, then it won't. Anti-pinch doesn't work half the time either.
Old Nov 14, 2016 | 06:04 AM
Lord Trazaza's Avatar
Glad to hear there's an easy fix. Almost ever day I angle the window up for style and the airflow when me or a friend is smoking. The other day I accidentally opened it all the way and it took like 5 minutes to close. It would reach a certain point and then open back up. What was weird was that it slowly got closer and closer to finally closing. I dread the day one of the driver or passenger side window motors goes...great I probably just jynxed myself lmao
interrupt
Drivetrain
Dec 28, 2018 09:07 PM
vashawn
Engine - Exhaust
Aug 13, 2016 09:23 AM
CheckOutThisGuy
Jul 27, 2016 01:10 AM
G35NBOOB
Jul 22, 2016 02:48 PM
SINNER_G
Jul 10, 2016 11:26 PM
