04 g35 coupe 6mt swap from 04 g35 sedan 5at
Old Oct 25, 2016 | 03:20 PM
infinitigman35's Avatar
ok so my question to you guys is. what exactly will i need to swap around from this motor to make sure it function properly.
i currently have a 04 coupe 6 speed. i spun the bearing on it. i was able to get a 2004 g35 sedan 5at motor.. obviously the flywheel and pilot bearing are going to have to be switched. i did notice that the o2 sensors are different. from what i can read, the fuel system has to be swapped as well as knock sensors and of course o2 will have to be switched. im wondering if any one experienced this kind of swap before and can let me know if anything else i might need to switch over?
Old Nov 3, 2016 | 12:08 PM
well to answer my own question yes those are the only things you need to change. knock sensor fuel injectors as well as o2 sensors. everything else will bolt right up.
AND MAKE SURE U WATCH OUT FOR THE PS PUMP LINES!!!!!!!
NOBODY WANTS A G35 WITH NO PS LIKE ME. ITS A PITA TO DRIVE LET ME TELL YOU. BUT I WILL GET IT FIXED SOON.
HOPE THIS HELPS SOMEONE IN THE LONG RUN.
