Window motor replace question
Old Nov 14, 2016 | 12:26 PM
Siciliang35's Avatar
When replacing the motor does anything need to be done beside replace the part? The window adjusts when closing the door
Old Nov 14, 2016 | 01:37 PM
LexD's Avatar
You will most likely need to reset the motor position when replacing the pwr. window motor.
Power Window Reset Procedure
2003-2005 G35 Coupe
  • Remove the Door Panel. 2003-2005 Front Door Panel
  • With the door open, lift UP and HOLD the Window Switch until the Window is fully closed.
  • Do not use the Window auto-closing function
  • Do not release the Switch before the Window is fully closed
  • Get inside the vehicle and close the door.
  • You need to close the door so the Door Switch is fully depressed
  • Press and HOLD the Window Regulator Motor Reset Switch. While holding the Reset Switch, press DOWN and HOLD the Window Switch until the Window is fully opened.
  • Do not use the Window auto-opening function
  • Do not release the Switch before the Window is fully opened
  • Release the Reset Switch. Then, lift UP and HOLD the Window Switch until the Window is fully closed.
  • Open the Door to release the Door Switch. The Window Glass should partially move down.
  • Re-install the Door Panel.
http://www.infinitihelp.com/diy/gcou..._procedure.php
Old Nov 14, 2016 | 01:51 PM
Thanks brother appreciate it
Old Nov 18, 2016 | 01:59 PM
Mignav01's Avatar
There's also a writeup with pics I believe in the DIY section, helped me a LOT
Old Nov 20, 2016 | 04:25 PM
Anyone know why when the window if fully closed there's a gap between the window and door . It's about 1/8 inch after replaced the motor
Old Nov 20, 2016 | 06:14 PM
Urbanengineer's Avatar
Coupe or sedan?
Old Nov 20, 2016 | 07:09 PM
It's 03 coupe
