P0300 Random Misfire
Old Nov 15, 2016 | 01:45 PM
LuisGee's Avatar
So my G is misfiring. But its not like a cyclinder misfire. Because all my spark plugs and coil packs are new and good. My question is what else can cause my G to misfire? Air leaks somewhere? Maybe replace some gaskets? I really dont want to take it to a mechanic so i could save money. But if i cant find the answer then that will be my last resort. Anyone have this problem?
Old Nov 15, 2016 | 01:48 PM
BradMD_96's Avatar
Vacuum leaks, bad petrol. Are you sure your coil packs are connected in the right order?
Old Nov 24, 2016 | 01:26 AM
expressme's Avatar
I have the same code but I have oil leaking in my spark plug it will spit and sputter I'll rev it 2 times an than goes away but when driving to can feel it jerk sometimes but it hasn't affected my porformance when I stomp the throttle it still runs good an beats all these little honda ricer **** boys around here
Also I have replaced all spark plugs an the coil pack that I had oil leak into
