g35 coupe window motor or window switch????
Old Mar 8, 2017 | 01:41 PM
jdmek100's Avatar
hi i have this interment issue with my window rolling up and down when it wants its gotten to the point that it does not work. i took it apart the other day to make sure all plugs were plugged up good then i did the motor reset button deal and it would roll up and down then up and down again then it would not roll down anymore and since then it has not rolled down. im curious i know the motors are issues with these cars but is there anyways i could find out if its the switch or the motor? the one thing im thinking its not the switch is because passenger side button on my side driving works and rolls that window up and down so it kinda gives me reason to think its the motor.
i guess i cant go wrong getting a new motor as im sure its the oem one to my knowledge. any advice on this would help me lots.
thanks in advance
Old Mar 8, 2017 | 03:56 PM
.cakestar's Avatar
its the motor. switch wouldnt cause that
Old Mar 8, 2017 | 05:04 PM
TurboRev's Avatar
sounds like the motor.
Old Mar 8, 2017 | 06:06 PM
Urbanengineer's Avatar
Motorrrrr. Pull it and check for carbon build up.
Old Mar 11, 2017 | 08:09 PM
jdmek100's Avatar
thanks I appreciate it
Old Mar 11, 2017 | 08:11 PM
jdmek100's Avatar
Thank you
jdmek100's Avatar
I did and there was build up...I went ahead and ordered motor thanks.
